How Do You Calculate the Constant in a Helicopter's Takeoff Equation?
The discussion focuses on calculating the constant A in the helicopter's takeoff equation y(t) = At^3, where the helicopter reaches a height of 15.0 m before releasing a crate. The user correctly derived the initial velocity of the crate as 6.2625 m/s using kinematic equations and determined A to be 0.0404 m/s³. The calculations were verified through the velocity function y'(t) = 3At², confirming the correctness of the approach and the final answer. The user expressed concerns about the magnitude of A but acknowledged that a smaller value is preferable for realistic helicopter dynamics.
  • Understanding of kinematic equations and their applications
  • Familiarity with calculus, specifically differentiation
  • Knowledge of unit analysis in physics
  • Basic concepts of helicopter dynamics and motion
  • Explore advanced kinematic equations in three-dimensional motion
  • Learn about the implications of different constants in motion equations
  • Study the principles of helicopter aerodynamics and performance metrics
  • Investigate the effects of gravitational acceleration on vertical motion
Students studying physics, particularly those focusing on mechanics and kinematics, as well as engineers interested in helicopter dynamics and motion analysis.
RJLiberator
As a helicopter carrying a crate takes off, its vertical position (as well as the crate's) is given as: y(t)= At^3, where A is a constant and t is time with t=0 corresponding to when it leaves the ground. When the helicopter reaches a height of h = 15.0m the crate is released from the underside of the aircraft. From the time the crate leaves the helicopter to the time it hits the ground, 2.50 seconds pass. Calculate A.
Kinematic equation: S = Si + Vi*t+1/2*a*t^2
given equation: y(t)=At^3
I first found the initial velocity that the crate left the aircraft using kinematics:
0=15+Vi*2.5+1/2*-9.81*2.5^2
Vi = 6.2625 m/s
Next, I took the derivative of the position function and got the velocity function y'(t)=3At^2
I then set 6.2625 = 3A*t^2
and noticed that using the first equation A=15/t^3
6.2625=3*15/t^3*t^2
simplified to
6.2625=45/t
t=7.1865
I then inputted this t time back into the original equation to find A
15=A*7.1865^3
A=0.0404
I added units of m/s^3 to the answer so that it cleared out in units.
Does this seem right?
Is it okay to add the units at the end here as m/s^3?
I don't like the answer A=0.0404, it seems to small.
It all looks good to me. It's okay that it turned out small, it would be worse if it turned out big; say A=1, then in just 10 seconds the helicopter would be moving vertically at 300 m/s!
Edit:
Yes, that was also correct.
Thanks for the help, that makes sense indeed.
I wanted to bump this post for any more opinions before I complete this assignment.
I feel "good" about my answer, but I don't feel conceptually happy about it.
  • · Replies 38 ·
