How can the limit of a function be determined without using a graph?
  • Thread starter Thread starter BayernBlues
    Limits
The limit of the function at x=2 does not exist due to the asymptotic behavior observed when evaluating the function near this point. By substituting values close to 2, it is evident that the function approaches positive infinity from the right and negative infinity from the left. This discrepancy confirms that the limit is split and ultimately does not exist. A sign graph can be utilized to illustrate the behavior of the function around critical points, such as roots and asymptotes. The analysis shows that the function diverges as it approaches x=2, validating the conclusion that the limit is undefined.
BayernBlues
http://img442.imageshack.us/img442/7875/pset33po8.png
I know that the answer is limit does not exist but I don't know how to show it mathematically on paper. Is there a way to show this without making a graph?
Plug in 2. You get a nonzero number over 0, which means dividing a common factor won't help. The graph is asymtotic at x=2. You can show which infinity the function goes to with a sign graph. Find all important numbers (roots, asymtotes) and evaluate the function in between each number. The graph will only change signs possibly at a root or asymtote. By plugging in values close to 2 on either side. You should see that the limit is split and does not exist
A quick way to check this is to see how does the numerator behave with x -> 2+ and x -> 2-, i.e.
2^3 + 3*2^2 + 4 = 8. Obviously, if x - > 2+, x^3 + 3x^2 + 4 > 8. Now,
x^3 + 3x^2 + 4 > 8
x^3 + 3x^2 + 4 / x - 2 > 8 / x - 2
Since on the right hand side the limit is + infinity, by the inequality we conclude that the limit on left is also + infinity. Now you can proceed with 2-... it may seem a bit long on paper, but it easily done mentally.
