Operator with strictly positive eigenvalues
4 replies · 2K views
physicus
Consider a Hilbert space with a (not necessarily orthogonal) basis [tex]\{f_i\}[/tex] Show that [tex]G=\sum_i |f_i\rangle\langle f_i|[/tex] has strictly positive eigenvalues.
I know that [tex]G=\sum_i |f_i\rangle\langle f_i|[/tex] is hermitian. Therefore, the eigenvalues are real and the Hilbert space has an orthonormal basis of eigenvectors of G. However, a general hermitian matrix does not need to be positive definite. Therefore, I need another approach.
I consider an eigenvector [tex]|a\rangle = \sum_i a_i |f_i\rangle[/tex] with [tex]G|a\rangle = \lambda|a\rangle[/tex]
[tex]\Rightarrow \lambda\sum_j a_j |f_j\rangle = \lambda |a\rangle = G |a\rangle = \sum_{ij}a_i |f_j\rangle\langle f_j|f_i\rangle[/tex]
[tex]\Rightarrow \lambda = \frac{1}{a_j}\sum_{i}a_i \langle f_j|f_i\rangle[/tex]
Unfortunately, I cannot conclude [tex]\lambda>0[/tex] from that.
Can anybody help me?
Unfortunately, I don't know how to relate G² and G.
[tex]G^2=\sum_{ij}|f_i\rangle\langle f_i|f_j\rangle\langle f_j|[/tex]
I would need an expression for [tex]\langle f_i|f_j\rangle[/tex] But since the basis set is not orthonormal I don't see what this could be.
Alright. Different approach. Let psi be an eigenvector of G with eigenvalue a. Then from the spectral equation you have
a=1/normsq(psi) * <psi|G|psi> = 1/normsq(psi) * sum (i) <psi|f_i><f_i|psi> = ...
Can you now show the dots hide a number > 0 ?
[tex]\ldots = \frac{1}{||\,|\psi\rangle||^2} \sum_i |\langle \psi | f_i\rangle|^2[/tex]
Since psi ist not the zero vector (as it is an eigenvector) its overlap with at least one of the basis vectors is non-zero. Therefore, the sum of squares is strictly greater than 0.
Thank you very much.
