Optimal location of receiver on a transmission line
In summary, the conversation discusses measuring a communications bus with an oscilloscope at various points along the line. It is mentioned that there will be reflections at each stub as well as at the ends of the bus if the impedance doesn't match. The person is interested in observing the resultant wave and asks if it matters where the oscilloscope is located in relation to the transmitter or ends of the lines. It is suggested to terminate the line and place the oscilloscope at the far end of the line. The conversation also mentions using a low-capacitance differential probe and a 75 ohm T connector for measurements.
Mike Vines
I am measuring a communications bus with an oscilloscope at various points along the line. I understand that there will be reflections at each stub as well as at the ends of the bus if the impedance doesn't match. I also understand that these reflected signals will add/subtract with the incident signal as well as change its phase. If I am interested in observing the resultant wave, does it matter where my oscilloscope is located in relation to the transmitter or ends of the lines?
For example, if I measure a 150-foot bus at 3 locations:
1) Immediately next to the transmitter at one extreme end of the bus
2) In the middle of the bus (at the 75 foot location)
3) At the extreme end of the bus opposite the transmitter
Will the waveforms look the same? The symbol rate is 1 MHz.
Thanks for any help.
No. The usual behavior on a non-terminated line is a positive reflection (bigger amplitude) at the far end and a negative reflection (lower amplitude) at the near end. You will get "ringing" at both ends.
Some calculations:
  • 150 feet is 45m
  • The signal speed in a copper line is 0.2m/ns
  • Thus the roundtrip delay (back and forth) is (90/0.2)ns = 450ns
  • If your symbol rate is 1MHz, you will have a lot of reflections in each symbol, since the symbol time is 1000ns
Likes Mike Vines
Svein said:
... behavior on a non-terminated line ..
Thank you for your reply. I should have mentioned that the line is terminated on both ends with its characteristic impedance of 78 ##\Omega##. I suppose that there will still be some slight reflections though, since it's unlikely to be perfectly matched. Would it then be a good idea to place my oscilloscope in the middle of the bus (away from the ends) to avoid seeing the ringing in the signal?
How is it terminated? Series or parallel can make a difference.
No. If you have a standard transmission line (not multidrop), the state of the signal at the end of the line is what matters. If you cannot decipher the signal with an oscilloscope there, you cannot expect a line receiver to do it.
I am somewhat surprised about 78Ω, however. I know about coaxial cable at 50Ω (RG-58) and 75Ω (RG-59) and twisted pair (100Ω to 120Ω). What kind of cable do you use?
Twisted pair setup
Likes Mike Vines
The wave form you see can be different at the source, middle and destination depending on how it's terminated.
There are some good articles on the web on why different termination strategies are appropriate in different situations.
http://web.cecs.pdx.edu/~greenwd/xmsnLine_notes.pdf
http://www.ti.com/lit/an/snla034b/snla034b.pdf
Likes Mike Vines
Place the oscilloscope at the far end of the line.
If the oscilloscope has a 50 ohm input impedance, connect it through a 27 ohm series resistor, (close enough to 28 ohm), to the end of the line. That will terminate the line by making it look like 50 + 27 = 77 ohms. There will be a 50/77 signal attenuation seen on the oscilloscope due to the termination.
If the oscilloscope is high impedance, use a T connector on the front of the oscilloscope, with the line on one side and the termination on the other. That will minimise reflections.
Do you have a 75 ohm T connector?
Take care when mixing 50 and 75 ohm connectors that look much the same. They can damage each other due to slight differences.
If possible use a 'T', 'Pi' or 'L' attenuator to convert between the 50 and 78 ohm worlds.
Likes Mike Vines
Just noticed this bit in bold..
Does that mean you have multiple receivers along the line?
Are you using a low-capacitance differential probe to make these measurements?
Thanks to all who replied. Here is some more information.
Here is the cable: goo.gl/Sbrsgi
CWatters said:
There are some good articles on the web on why different termination strategies are appropriate.../QUOTE]
Thank you for pointing me to those references. I will take a look at them.
The line is terminated with a 78 ohm resistor when I measure at the stubs along the line. When I measure at the end of the line, I remove the terminating resistor and plug it directly into the 50 ohm scope. Would this (goo.gl/YlikNS) 75-to-50 ohm connector be a good choice to interface to match the line/scope impedances?
Yes, I have multiple receivers along the line. I would like to look at the signal at each receiver/stub and at the end of the line to see if they are all receiving the same signal. I thought the reflections might affect the signal integrity depending on where I measured.
I initially was using another piece of twinaxial cable to make a single-ended measurement. Upon realizing that I was grounding the negative conductor, I picked up a test cable that split the positive and negative conductors out into two coaxial cables (equal length) with BNC adapters. I connect the coax cables to Channels 1 and 2, respectively. I then do (Ch.1 - Ch.2) to get the differential signal. I assume the capacitance would be similar to that of the cable. Do I need a special probe? I had read somewhere that I might need an active differential probe to remove common mode voltage, but I don't know how important that is.
Oops - if you attach stubs to a transmission line, you get all kinds of reflections. On a multidrop line, the "stubs" should preferably be less than 5mm.
You are using twinaxial cable, not coaxial cable. Coaxial adapters will not help you.
With respect, your whole measurement approach appears flawed. Can you post your statement of purpose for this experiment, and your whole approach? I don't think we can help you much if you post small bits of what you are trying to do.
A balanced diff probe is fundamental to any TL measurements, and if you are not understanding why, it's very hard to give you good quality help on your TL experimental investigations, IMO.
What is the purpose of finding the optimal location of a receiver on a transmission line?
The optimal location of a receiver on a transmission line is important because it allows for maximum signal reception and minimum signal loss. This ensures efficient and effective communication through the transmission line.
How is the optimal location of a receiver on a transmission line determined?
The optimal location of a receiver on a transmission line is determined by analyzing factors such as distance from the transmitter, impedance matching, and environmental conditions. Mathematical calculations and simulations are often used to determine the ideal location.
What are the consequences of not having an optimal receiver location on a transmission line?
If the receiver is not placed at the optimal location on a transmission line, there can be significant signal loss and distortion, leading to poor communication quality. This can also result in increased costs for maintaining and operating the transmission line.
Are there any industry standards or guidelines for determining the optimal location of a receiver on a transmission line?
Yes, there are industry standards and guidelines that provide recommendations for determining the optimal location of a receiver on a transmission line. These standards are based on extensive research and experience in the field of communication and transmission engineering.
Can the optimal location of a receiver on a transmission line change over time?
Yes, the optimal location of a receiver on a transmission line can change over time due to various factors such as changes in environmental conditions, equipment upgrades, or changes in communication needs. It is important to regularly reevaluate and adjust the receiver location to ensure optimal performance.
  • Electrical Engineering
