- 7,781
- 4,061
kubikat said:And here is the beam pattern that I see when beam comes out of the laser and hits the first lens after the focal point (this one is when the path length of the beam is rather short). I am not sure why I get the rings.
Here is how the beam profile changes as it travels longer distances. At certain distance I can make the "hole" in the center disappear and then the center of the beam seems to be gaussian.
Before I get to these images, here's two photos of my setup:
[PLAIN]http://img585.imageshack.us/img585/3264/dsc01324u.jpg
[PLAIN]http://img691.imageshack.us/img691/5079/dsc3306.jpg
The tweezers are coupled into an upright microscope that uses infinity-corrected objectives, so the beam coming out of the tweezer module is (nearly) collimated. The top view of the module has the following components (in order): Nd:YAG laser, mirror, 40 mm plano-convex lens, mirror, 250 mm plano-convex lens. Inside the microscope there's another mirror, directing the beam down into the objective lens. the tweezer module sits on top of a 4-axis positioner (x, z, tip, tilt) that allows me to bring the tweezer beam into alignment with the optic axis of the microscope.
Here's an image of the spot at the sample plane:
[PLAIN]http://img707.imageshack.us/img707/1190/flycap0.jpg
and slightly defocused:
[PLAIN]http://img574.imageshack.us/img574/7902/flycap1.jpg
For these images, I used a 100x NA 0.9 objective- I generally trap with a 63X 0.9 dipping objective, tho. The two small dots/interference fringes are caused by the mirror in the microscope, and are not actually present at the sample, AFAIK.
Your beam images look ok, there's perhaps a hint of astigmatism (the spots are not perfectly symmetric, there appears to be a feature at about 45 degrees on one image). This can be minimized by tip/tilt adjustments of your lens. At the trap, astigmatism will manifest by a jet of particles shooting off to one side.
I'm not seeing any evidence that your laser is multimode- can you take some images of the focused spot? Put a mirror in place of the sample (lay a coverslip on top of the mirror if your objective requires one), and take a picture of the reflected spot.
Can you make a trap?
