Undergrad Order of integration and taking limits
The discussion centers on the order of operations in contour integration, specifically whether taking a limit before or after performing an integral yields the same result. It is confirmed that the order does matter, and the Dominated Convergence Theorem and Fatou's Lemma are referenced as helpful resources for understanding this concept. Additionally, the challenge of integrating the exponential of an exponential is acknowledged, with a suggestion to ensure the conditions for exchanging limits and integration are met. The importance of having a dominating function to prevent divergence in integrals is emphasized. Overall, the conversation highlights the complexities of integration in complex analysis, particularly from a physics perspective.
dyn
Hi.
I came across the following integral in contour integration
lim(ε→0) "integral of" exp(iaεe) dθ = θ
If I take the limit first then it just becomes the integral of 1 which is θ.
I have 2 questions -
If I take the limit first and then perform the integral do I always get the same answer as when I do the integral first and then take the limit ? In other words does the order of operations matter ?
If I wanted to do the integral first , how do I integrate the exponential of an exponential ? I have never seen one before.
Thanks
dyn said:
Hi.
No.
Yes.
There are two helpful results for the real case in this context:
https://en.wikipedia.org/wiki/Dominated_convergence_theorem
https://en.wikipedia.org/wiki/Fatou's_lemma
It would probably be easier to prove that the conditions for an exchange of limit and integration are given.
Thanks for your reply. I am learning complex analysis from a physics background and to be honest most of those references were over my head
The best explanation I had found is
"Even if all ##f_n## and the limit function ##f## are integrable, the convergence of the integral sequence does in general not hold! The integrable major function (first link) prevents the sequence of functions ##f_n## from escaping to infinity."
This means we need something that dominates the limit sequence from above. As all your function values are on the unit circle, I guess this could be achieved in this case. And as a side note: physicists don't bother as long as the result matches their experiments, but do not quote me on that. :wink:
