Ordering Force Functions: Reasoning & Explanation
The discussion centers on determining the order of force functions based on the work done to move an object along the x-axis. The key concept is that the area under the force versus distance graph represents the work done, with larger areas indicating more work. Participants suggest comparing the areas visually to rank the functions without calculations. One user proposes an order of B, A, D, C, but is corrected for reversing the order from least to most work. The conclusion emphasizes that the function with the smallest area corresponds to the least work required.
Calc 2
The graphs show the force Fi (in pounds) required to move an object 9 feet along the x-axis. Order the force functions from the one that yields the least work to the one that yields the most work without doing any calculations. Explain your reasoning.
http://img227.imageshack.us/img227/9098/picrn.png
This is in my Calc 2 book and I don't know much or anything about physics, but I'm assuming you can use something similar to the concept of vectors to find this out? I hav no real idea how to come to a solution to this problem.
The area under a graph gives the product of the axes. So Force vs. distance will give Area = Force*distance, which is work! So you just need to compare the areas.
So without doing any calculations, that would mean the biggest area is the one that requires the most work and the smallest, the least? And the order of the functions would go:
B, A, D, C?
B, A, D, C?
You have it ordered from biggest to least instead of the other way around.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 36 ·
