Oscillating Mass between Two Springs
4 replies · 35K views
kppc1407
A block on a frictionless table is connected to two springs having spring constants k1 and k2. Show that the block's oscillation frequency is given by f = (f12 + f22).5 where f1 and f2 are the frequencies at which it would oscillate if attached to spring 1 or spring 2 alone.
f = 1/T
T = 2pi(m/k).5
I have substituted the period into the frequency and I am stuck. It looks like they found f1 and f2 alone and put them into the Pythagorean theorem, but I do not know how to relate them.
f = 1/T
T = 2pi(m/k).5
I do not see any relation to Pythagorean theorem. Notice that if you were to latch two springs onto a mass, you could model the same motion with one spring with a constant equal to the sum of the two springs. Knowing this, calculate the frequency of all three configurations(spring 1, spring 2, and spring 1 & 2 combined). Next, substitute your answer for spring 1 and spring 2 into that equation and see if you get the same answer you derived for spring 1 & 2 combined.
When I find the frequencies of the springs, I do not understand how to relate them.
I told you how.
Calculate frequency 1 with k = k1, frequency 2 with k = k2, and f with k = k1 + k2.
[tex]f_1 = \frac{1}{2\pi} \sqrt{\frac{k_1}{m}}[/tex]
[tex]f_2 = \frac{1}{2\pi} \sqrt{\frac{k_2}{m}}[/tex]
[tex]f = \frac{1}{2\pi} \sqrt{\frac{k_1 + k_2}{m}}[/tex] because [tex]k = k_1 + k_2[/tex] and nothing else changes.
Next, plug [tex]f_1[/tex] and [tex]f_2[/tex] into [tex]f=\sqrt{f_1^2+f_2^2}[/tex] to see if you get the same expression as above for [tex]f[/tex].
(you do)
Oh, I was going a different route using a different equation making it more complicated. Thank you for your help.
