Can a Phase Constant Be Determined from Given Oscillation Data?
  • Thread starter Thread starter SkinlessSpore
    Oscillating Spring
The discussion revolves around calculating the force constant (k), total energy, and position equation (x(t)) for a 3kg object oscillating on a spring with a 10 cm amplitude and 2 Hz frequency. The force constant was calculated using the formula k = (4π^2)(m)/T^2, yielding a value of approximately 473.74 N/m. For total energy, there was confusion about whether to use amplitude or another value for x in the energy equation. The position equation was correctly formulated as x(t) = 0.01sin(4π t + φ). The possibility of determining the phase constant from the given data was questioned but remains unresolved.
SkinlessSpore
A 3kg object is attached to a spring and oscillates with an amplitude of 10 cm and frequency f = 2 Hz
a.) What is the force constant k of the spring?
b.) what is the total energy of this motion?
c.) Write an equation for x(t) describing the position of this object relative to its equilibrium position. Can phase constant be determined from the information given?[/B]
k = (4π^2)(m)/T^2
TE= 1/2kx^2+1/2mv^2
1/2kA^2 = 1/2kx^2+1/2mv^2[/B]
a.) k = 4π^2(3)/(0.5)^2 = 473.74
b.) First I attempted to find the velocity from the equation 1/2kA^2 = 1/2kx^2+1/2mv^2 I have trouble putting something in for x. Should I just put the amplitude in for x?
c.) x(t) = 0.01sin(4π t + φ)
[/B]
Welcome to PF!
Parts (a) and (c) look good except that you have not included units. Do you need to worry about significant figures?
Hint for (b): Does it matter at which point of the motion you calculate the energy?
Likes SkinlessSpore
TSny said:
Welcome to PF!
Thank you!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
