Oscillations of a free hanging chain
The discussion revolves around deriving the equation of motion for a free hanging chain of mass m and length L, modeled as a differential equation. The chain is described as hanging vertically downwards, with variables defined for vertical and horizontal measurements.
  • Participants discuss the derivation of a differential equation for the chain's motion and the implications of variable transformations. Questions arise regarding the correctness of the initial equation and the interpretation of derivatives with respect to different variables.
There is an ongoing exploration of the relationships between the variables and their derivatives. Some participants provide guidance on the need to convert the equation into a form that uses the new variable ξ, while others express confusion about the transformations and the notation used.
Participants note the importance of correctly defining the direction of measurement for the variable x and the potential implications this has on the derived equations. There is also mention of a specific trial solution and its relation to Bessel's equation, indicating a complex mathematical context.
kregg34
I am trying to find an equation for a free hanging chain of mass m and length L. The chain is hanging vertically downwards where x is measured vertically upwards from the free end of the chain and y is measured horizontally.
[/B]
I derived this differential equation for the chains motion,
(1/g)(second derivative of y with respect to t) = (derivative of y with respect to x) + x(second derivative of y with respect to x)
Trial solution that was given is,
y = u(x)cos(ωt) where x ⇒ ξ and ξ = √x and u(x) ⇒ s(ξ)
[/B]
By putting y into the equation above I get,
-((ω^2)/g)u(x) = u'(x) + xu''(x) where the ' means the derivative with respect to x
I think its implied that -((ω^2)/g)s(ξ) = s'(ξ) + xs''(ξ) ... equation 1
After changing the variable to s(ξ) I'm suppose to get a Bessel's equation of order zero I think.
so from the change of variables,
u(x) ⇒ s(ξ)
s'(ξ) ⇒ u'(√x) = (u'(√x))/(2√x) right?
and from quotient rule I got,
s''(ξ) ⇒ u''(√x) = (u''(√x) - u''(√x)(1/√x)) / (4x)
plugging these into equation 1 I get,
(x^2)s''(ξ) + x^(3/2)s'(ξ) + (((ω^2)x^2)/g)s(ξ) = 0
but the bessel equation looks like
(x^2)s''(ξ) + (x)s'(ξ) + constant(x^2)s(ξ) = 0 which has x instead of x^(3/2)?
Not sure what I did wrong?
It doesn't seem right to have a dy/dx term in your very first equation. I would have thought it should be the standard string vibration equation, except for a factor x in the tension term.
On the question it actually gives you that equation, you have to derive it, and that's what it is
kregg34 said:
The chain is hanging vertically downwards where x is measured down
For this to be the correct equation, I think you need to take x as increasing upward from the lower end of the string.
oh sorry, that's how I derived it but I wrote it wrong. x is measured from the free end of the chain upwards
No. To get the equation for s(ξ), you will need to start with -((ω^2)/g)u(x) = u'(x) + xu''(x) and transform it to the equation for s(ξ) by using the definition ξ = √x. The chain rule for derivatives will be useful here.
Not sure I understand. Cause I thought the transformations of u(x) were basically saying u(x) = s(√x). So I took the derivative of both sides with respect to x and substituted u'(x) and u''(x) in
In obtaining equation 1, it appears to me that you are simply replacing u'(x) by s'(ξ) and replacing u''(x) by s''(ξ).
Take a specific example. Suppose u(x) = sin(√x). So, with ξ = √x, you have s(ξ) = sin(ξ).
What is u'(x)? What is s'(ξ)? Does u'(x) = s'(ξ)?
u(x) ⇒ s(ξ)
Note that you have claimed u'(√x) = (u'(√x))/(2√x). If you cancel u'(√x) from both sides, you are left with 1 = 1/(2√x).
What is u'(x)? What is s'(ξ)? Does u'(x) = s'(ξ)?Note that you have claimed u'(√x) = (u'(√x))/(2√x). If you cancel u'(√x) from both sides, you are left with 1 = 1/(2√x).
u'(x) = cos(√x)/(2√x)
s'(ξ) = cos(ξ) (dξ/dx)
and ξ = √x so
dξ/dx = d√x/dx = 1/(2√x) aren't they the same? or should I write
s'(ξ) = cos(ξ) (dξ/dξ) = cos(ξ) with respect to ξ instead of x?
OK, I see where you're coming from. You are interpreting all primes as meaning derivative with respect to x. However, since s is considered a function of ξ, the notation s'(ξ) would normally denote the derivative of s with respect to ξ. So, in the example, s'(ξ) = cos(ξ).
What you need to do here is convert the differential equation involving u and x into a differential equation involving s and ξ. In the differential equation for s, derivatives should be with respect to ξ and the symbol x should not appear.
Figured it out, thanks man!
Good work!
  • · Replies 19 ·
