Oscillatory motion (vertical spring-mass system)
The discussion revolves around the dynamics of a vertical spring-mass system subjected to an oscillatory driving force. Participants explore the equations governing the motion, the effects of varying frequencies, and the implications of initial conditions on the system's behavior.
  • One participant presents the equations of motion for a spring-mass system under an external force, questioning the form of the solution for velocity and position over time.
  • Another participant clarifies that the system is driven by an oscillatory force and questions whether the discussion pertains to homework.
  • A participant confirms that the external force is indeed given by 10sin(wt) and discusses their findings for w = 2 rad/sec, presenting a derived equation for velocity.
  • Concerns are raised about the fixed nature of the natural frequency (ω0) and the formulation of the differential equation governing the system's motion.
  • One participant suggests examining the conditions of the solution and provides a plot for a specific frequency, indicating the behavior of the system at that frequency.
  • Another participant discusses the rationale behind assuming a general solution form and its relation to the derivatives of the motion equations.
  • A later reply emphasizes the need for a general solution to satisfy both the driving force and initial conditions, indicating the complexity of the system's response.
  • One participant expresses gratitude for the assistance received in understanding the material, indicating a learning process.
Participants exhibit a mix of agreement and disagreement, particularly regarding the formulation of the differential equations and the implications of initial conditions. No consensus is reached on the correctness of specific derived equations or the overall approach.
Participants note the importance of matching units on both sides of the differential equation and the necessity of considering initial conditions when deriving solutions. Some assumptions and dependencies on definitions are acknowledged but remain unresolved.
This discussion may be useful for individuals interested in the dynamics of oscillatory systems, particularly in the context of spring-mass models and the effects of external forces on such systems.
gramentz
"Resonance in an un-damped spring-mass system"
If I have a force that is pushing upwards on a spring-mass system, and I basically have to find an equation that will give me the velocity and y-position for any given t, how much does that differ from the general form of Asin ([tex]\omega[/tex]t +[tex]\phi[/tex])?
This is what I know:
m= 2
k= 32
Vertical position y of mass: dy/dt = v
Velocity of the mass: dv/dt = f(t)/M - (k/M) * y
I know the external force is f(t) is 10sin([tex]\omega[/tex]t)
I know that y(0) and v(0) are zero.
I have to find the position and velocities when [tex]\omega[/tex]= 2, 3, 3.5, 4, 4.5, 5 rad sec and I have to use 40,000 time steps (totaling 25 seconds) where each step is 0.000625.
I know that the "preferred" frequency of the system will be at 4 rad/ sec, using [tex]\omega[/tex]= [tex]\sqrt{\frac{k}{m}}[/tex]
This is where I am having a bit of trouble: I found that when I'm examining 2 rad/sec, that v'' = 5cos2t - 16y', or that v'' = 5cos2t-16v. What I'm trying to do, is find the velocity and position of this system for any given value of t.
I was told that I can use the "general" solution of this type: v= A cos 2t + B cos 4t + C sin 2t + D sin 4t.
Am I in the right direction? Any insight would be appreciated. Thanks in advance!
Is this being driven by an oscillitary force, such as F(t) = F0sin(ωt) ?
Is ω0=sqrt(k/m), where ω0 ≠ ω ?
Is this homework??
Bob S
No, this isn't homework.
Yes, the external force that is applied is given by 10sin(wt) where w will vary.
I am first examining what happens when w = 2 rad/sec.
I've been working on this and came up with the following at 2 rad/ sec (don't know if it is correct)
dv/ dt = 5sin(2t) - 16y
since y' = v, y= v^2/2
dv/ dt = 5sin(2t)- 8v^2
dv/dt +8v^2 = 5sin (2t)
8v^2 dv = 5sin (2t)dt
(8/3)v^3 = (-5/2)cos(2t)
v = cubed root of (-15/16 cos (2t))
Isn't sqrt(k/m) fixed at sqrt(32/2) = w0 = 4 radians per second?
Isn't your differential equation
y'' +w02y = (10/m) sin(wt) [STRIKE]- g[/STRIKE] where the right hand term is the driving term?
where w0= sqrt(k/m)
Note that the units on the left hand and right hand sides have to match.
Bob S
Hi gramentz-
Look at the thumbnail and see if it fits all conditions, including driving force and two initial conditions.
[added] Here is a thumbnail plot of the solution using w=3.5 radians per second, and w0 = 4 radians per second. Both the amplitude and derivative are zero at t=0.
Bob S
When we assume the general solution of the form y= csin(w0t) + dcos(w0t)...is this because all of the derivatives will take such form? Since dy/dt = v in the original equation I was given, that implies that step 7 in the thumbnail could also be v(t)? Thank you for helping me with this.
Hi gramentz-
The particular solution provides the long-term (steady state) solution to match the driving force, especially when there is damping. But the particular solution does not match the initial conditions; specifically y(0) = y'(0) = 0. To do this, we need a solution to [4] with two arbitrary constants that can match the particular solution [1-3] to the two initial conditions. So that is why a general solution of the form [5] was chosen. The final solution [8] matches the two initial conditions at t=0, AND the particular equation [1] at all times.
Bob S
It took me quite some time, but I finally understand what you wrote and how you arrived at your answers. Thanks for taking the time to help me out, I appreciate it.
  • · Replies 30 ·
