Osmotic Pressure and Equilibrium constant
2 replies · 5K views
WK95
An aqueous solution contains 0.84 g/L of an organic detergent. The osmotic pressure of this solution is 54.4 torr, at 25°C. What is the molar mass (in g/mol) of this detergent?
##pi=MRT##
##R=0.08206L*atm/(mol*K)##
##pi=MRT##
##M=pi/(RT)##
##M=(54.4 torr * 1 atm/760 torr)/(0.08206L*atm/(mol*K))(298.15 K)##
This is wrong but I;m not sure why and how to get the right asnwer.
What is the equilibrium constant expression for the following reaction:
PtCl42−(aq)↔Pt2+(aq) + 4Cl−(aq)
Choose from the list below and enter the letters alphabetical order. (e.g. For an equilibrium constant of [Cl-]4eq[Pt2+]eq enter AH.)
A) [Pt2+]eq E) [Cl-]-1eq I) [PtCl42-]4eq
B) [Cl-]eq F) [PtCl42-]-1eq J) [Pt2+]-4eq
C) [PtCl42-]eq G) [Pt2+]4eq K) [Cl-]-4eq
D) [Pt2+]-1eq H) [Cl-]4eq L) [PtCl42-]-4eq
##pi=MRT##
##pi=MRT##
##M=pi/(RT)##
It's quite difficult to follow what you have done here.
For the first part, please define the variables used.
For the second part, use the subscript and superscript tags or LaTeX to format your working.
The osmotic pressure satisfies the same equation as the ideal gas law. In your problem solution, you need to use the density of the detergent.
[tex]ρ=\frac{p_iM}{RT}[/tex]
You need to solve for M.
