What is the enthalpy of what at 5 bars?
  • Thread starter Thread starter PCal
    Gas Temperature
The enthalpy at 5 bars is established as 2018 kJ/kg, specifically concerning the flue gas exiting the boiler. The discussion highlights the importance of knowing the flue gas temperature, which is approximately 300°C, and the mass flow rates of both the water and flue gas for accurate calculations. The heat capacity at 90°C is noted as 4.208. Clarity on whether the calculation pertains to the pre-heater, boiler, or both is essential for resolving the assignment question.
  • Understanding of thermodynamics, specifically enthalpy calculations.
  • Familiarity with heat transfer principles in boiler systems.
  • Knowledge of flow rate measurements in chemical processes.
  • Basic proficiency in using thermodynamic tables and charts.
  • Research the calculation methods for enthalpy in thermodynamic systems.
  • Learn about the role of heat capacity in energy transfer processes.
  • Investigate the impact of flow rates on thermal efficiency in boilers.
  • Explore the relationship between temperature and enthalpy in flue gas systems.
Students in thermodynamics courses, engineers working with boiler systems, and professionals involved in energy management and efficiency optimization.
PCal
If the flue gases exiting the boiler are used to preheat the water fed to the boiler from a temperature of 28 C to 90 C and assuming:
• a mean specific heat capacity for water over this temperature range to be 4.2 kJ kg–1 K–1
a mean molar heat capacity for the flue gases up to 300°C to be 31 kJ kmol–1 K–1
10% of the heat required to heat the water is lost in the heat exchanger
all water entering the system is converted to steam
determine the final outlet temperature of the flue gas
Enthalpy at 5 bar = 2018kJ/kg
Flame temp= 1997°C
Heat in =(sensible heat in fuel and air + latent heat released by combustion)
Heat out=Σ(mass×mean specific heat capacity×Tf) for each of the products of combustion.
This is the final question on my assignment and I'm clueless as to where I should even start as the lesson seems to give no guidance. Help would be massively appreciated!
Are you trying to do the calculation just for the pre-heater, for the combination of preheater and boiler, or for each of them separately?
If I'm correct, just the outlet temperature from the pre-heater. The question isn't particularly clear but that's my assumption!
Do you know the flue gas temperature coming out of the boiler? Do you know the mass flow rates of the water and the flue gas? or, Do you know the flue gas temperature going into the boiler?
I think the flue gas coming out of the boiler is 300° C but tha's not very clear, The flow rate of the flue gas = 1400 kmol h-1, Enthalpy at 5 bar = 2018kJ/kg, the heat capacity at 90°=4.208. As far as I can tell that's all I've got
The enthalpy of what at 5 bars is 2018 k/kg? Do you know the water flow rate?
What is the full exact problem statement?
  • · Replies 30 ·
  • · Replies 16 ·
