Parallel and Series Resistor Simplification
The discussion revolves around simplifying a circuit with parallel and series resistors, where the user was confused about the correct approach to combine resistors at a specific node. The user initially attempted to simplify the circuit but arrived at an incorrect answer. The correct equivalent resistance for the entire circuit is stated as 9 ohms, while the value for 'R' is 15 ohms. A key suggestion was made to remove a shorted 30-ohm resistor from the network to achieve the correct simplification. Ultimately, the user resolved the issue independently before receiving further assistance.
nlm
Hi,
I need help simplifying this circuit with parallel and series resistors. I am mainly confused, because there seems to be a point in my simplification where in picture 4 and 5 of my second image where the remaining 3 resistors are connected by 1 node.
I tried to simplify them as resistors in parallel, but I end up with the wrong answer, and this doesn't seem like the correct thing to do.
The Resistor equivalent of the entire circuit is 9 ohms. And the answer for 'R' is 15 ohms. However I do not know how to obtain this answer.
Series Resistors = R1 + R2 = Rtotal
Parallel = R2*R1/R1+R2 = Rtotal
= 1/R3 + 1/R2 + 1/R1 = Rtotal
Here are the images of my attempted solutions:
image 1 (the problem):
http://img22.imageshack.us/img22/9206/resistor1.jpg
image 2 (my analysis):
http://img22.imageshack.us/img22/4978/resistor2.jpg
Any help would be appreciated.
the 30ohm resistor is shorted so just remove it from the network and u'll get the right answer.
Yes, thank you.
I actually figured it out before the forum posted my question.
  • · Replies 34 ·
  • · Replies 17 ·
12K
