Parallel Lines between Two Blocks (Latex)
2 replies · 4K views · last reply
EngWiPy
Hello all,
I have two blocks, and I want to draw multiple parallel lines between them. This is the Latex code I have
Code:
\documentclass{article}
\usepackage{tikz}
\usetikzlibrary{shapes,arrows,fadings, shadows}
\usepackage{amsmath,bm,times}
\begin{document}
\pagestyle{empty}
\tikzstyle{sensor}=[draw, fill=blue!20, text width=5em,
    text centered, minimum height=2.5em]
\tikzstyle{naveqs} = [sensor, text width=4em, fill=gray!40,
    minimum height=12em, rounded corners, shade, drop shadow]
\begin{tikzpicture}
\node (naveq) [naveqs, name=S2P] {S/P};
\node (naveq) [naveqs, name=FFT, right of=S2P,node distance=3cm] {FFT};
\end{tikzpicture}
\end{document}
What is the best way to do so?
Thanks in advance
DrDu said:
How about
\hline{\textwidth}
\hline{\textwidth}
I am using Tikz/PGF package. I am not sure if the above control sequences work within. Besides, I need to control the positions of those horizontally parallel lines. In particular, I need two lines above the middle, three vertical lines, and then one line at the bottom.
I appreciate if you can integrate the suggestion into the code to see how it will work.
Thanks
