Parallel Plate Capacitor Diameter
2 replies · 6K views · last reply
tomizzo
Two circular disks spaced 0.50 mm apart form a parallel-plate capacitor. Transferring 1.70 ×109 electrons from one disk to the other causes the electric field strength to be 3.50 ×105N/C.
What are the diameters of the disks?
Refer to attachment
So I substitute everything into the formula and end up getting R = .5 mm. I then double this to find the diameter and still get the wrong answer. Any ideas?
  • Equation for the electric field on the axis of a uniformly charged disk: E_disk at z equals eta over 2 epsilon-zero times the quantity 1 minus z over the square root of z squared plus R squared.
Refer to attachment
Not sure what you're intending to do with that equation you attached. It looks like the on-axis field for a charged circular disk at some distance z from the disk along the axis. But here you have a parallel plate capacitor and the field will be (essentially) uniform between the parallel plates.
Look instead to formulas related to parallel plate capacitors.
