Parallel plate capacitor electric field problem
8 replies · 17K views · last reply
megr_ftw
Two circular disks spaced 0.50 mm apart form a parallel-plate capacitor. Transferring 1.8*10^9 electrons from one disk to the other causes the electric field strength to be 1.3* 10^5 N/C. What are the diameters of the disks?
F=k(q1)(q2)/r^2
E_capacitor= Q/(epsilon_0)*A
I'm doing the same problem.
All I can find from the second equation is that Q = Epsilon * A * E
Which doesn't really help because even if I break down A into pi * r^2 I still don't know r.. because if I knew r I would know d, which is what we're looking for.
I don't get how that helps.
Well I have another equation I was solving for earlier.
r = sqrt(Q/pi*eta)
I suppose I could substitute that into the equation set equal to Q and solve for Q.
Then maybe I could plug that Q from Q=Epsilon*A*E into the r = sqrt(Q/pi*eta) equation to find r.
Hmm. I can't stand this because of the precision required for these stupid online assignments, I get zero credit or full credit, none in between. Rewarded none for the effort I've put forth the same as someone who did nothing.
Oh well, computers give grades.
And now I end up with
Q=(Epsilon*E*Q) / eta
that makes no sense because if I go any further the Q's will cancel out *sigh*.. so I know I did something wrong.
Back to the drawing board.
Look at your second equation.
You know Q, you know ε0 and you know E. Can you find A? Once you know A can you find the diameter?
What is Q?
N electrons * Charge of electron?
I'm going back and re-reading the entire chapter leading up to this one in cased I missed something.
I'm completely lost when it comes to electricity and that's not like me.
thanks for the help. now if only webassign would stop lagging all the time and I could see if my answer is correct or not...
myxomatosii said:
What is Q?
Yes, Q is the total charge of the N electrons.
