Calculating the Tangent to a Parametric Curve at a Given Point
The discussion revolves around calculating the tangent to a parametric curve defined by x=6cos(2t) and y=t^(5/2) at t=π/4. A participant initially calculated the tangent line as y=-0.145x+0.547 but received feedback indicating the answer was incorrect. The confusion stems from the proper interpretation of the equation for y, which was clarified to be y=t^(5/2). Participants emphasized the importance of showing all work to identify errors in the calculations. Accurate notation and clear communication of mathematical expressions are crucial for resolving such problems.
53Mark53
Consider the parametric curve given by:
x=6cos(2t),
y=t5/2.
Calculate the equation of the tangent to this curve at the point given by t=π/4, in the form y=mx+c.
The tangent is given by y=
[/B]
the answer that I got was y=-0.145x+0.547 but it says that it is wrong
I did this by subbing in the value of t for x and y and also the differential of x and y and then calculating the slope
but I am not sure what I have done wrong
x=6cos(2t),
y=t5/2.
[/B]
How can we know what you did wrong if you do not show your work?
x=6cos(2t),
y=t5/2.
[/B]
Do you mean ##y = (5/2)t##, ##y = t^{5/2}##, ##y = t^5/2 = \frac{1}{2} t^5##, or what? Use parenthesis, like this: y = (5/2)t or y = t*(5/2) or y = t^(5/2) or y =(t^5)/2, or whatever is appropriate.
sorry the question didnt copy properly it should say t^(5/2)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
