Parametric Derivative Derivation
7 replies · 5K views
courtrigrad
How does one conclude that [tex]\frac{d^{2} y}{dx^{2}} = \frac{dy\'/dt}{dx/dt}[/tex]?
Thanks
[tex]\frac{d^2 y}{dx^2} = \frac{d \dot{y'}}{d \dot{x}}[/tex]
[tex]= \frac{dy'}{dx} = \frac{dy}{dx^2}[/tex]
Which is clearly incorrect.
cronxeh said:
Well if you googled "parametric derivative" you would've stumbled on your answer in about 3 seconds:
http://www.mathwords.com/p/parametric_derivative_formulas.htm
And, you will notice that what you wrote was incorrect. What is true is that [tex]\frac{dy}{dx}= \frac{\frac{dy}{dt}}{\frac{dx}{dt}}[/tex] not the second derivative.
That follows from the chain rule.
I didn't write
[tex]\frac{d^{2}y}{dx^{2}}= \frac{\frac{dy}{dt}}{\frac{dx}{dt}}[/tex]
. I wrote [tex]\frac{d^{2}y}{dx^{2}}= \frac{\frac{dy'}{dt}}{\frac{dx}{dt}}[/tex]
Yes. Oops.
[tex]= \frac{dy'}{dx} = y''[/tex]
Then is y' the derivative with respect to x or t? If with respect to t, then your equation is wrong. If with respect to x, then you are back to the first derivative case.
