Parametric Equation of a Line from the intersection of two planes
The discussion revolves around finding the parametric equation for the line of intersection of two planes defined by the equations x + 2y + 3z = 0 and 4x + 5y + 6z = 5. Participants explore the implications of manipulating the equations of the planes and the geometric interpretations of their intersection.
  • The original poster attempts to equate the two plane equations to find a relationship, questioning whether this leads to the correct representation of the line of intersection. Other participants raise concerns about the validity of this approach and the implications of mixing the two planes.
The discussion is ongoing, with participants providing insights into the original poster's method and clarifying the nature of the equations derived from the planes. Some guidance is offered regarding the appropriate methods for finding the intersection, specifically mentioning the use of normal vectors and cross products.
Participants express confusion about the relationship between the derived equations and the original planes, particularly regarding the loss of information when manipulating the equations. There is an emphasis on the need to restrict the derived plane to values that satisfy both original plane equations.
Aneeshrege
Find the parametric equation for a line of intersection of these two planes
x+2y+3z=0
4x+5y+6z=5
Normal to plane 1= <1,2,3>
Normal to plane 2= <4,5,6>
I know the way to do this problem is to take cross product of two normals etc etc,
but i want to know if the way i did this is correct also.
I already turned the work in so there's nothing i can do to change it but the curiosity is killing me.
First, i set the two planes equal to each other
4x+5y+6z-5=0
x+2y+3z=0
=> x+2y+3z=4x+5y+6z-5 (please correct me my thinking process is wrong,im winging it)
=> 3x+3y+3z=5
=> x+y+z=5/3 (now I am thinking this is the equation of the intersection of the two planes but this isn't the equation of a line, it looks like a plane, or is it?)
so i took a point on this set, (5/3,0,0) and two other points (0,5/3,0) and (0,0,5/3)
i did <0,0,5/3> - <0,5/3,0> = <0,-5/3,5/3> as a directional vector.
so L(t)= (5/3,0,0) + <0,-5/3,5/3>t
x=5/3
y=-5/3t
z=5/3t
IS any of this wrong?!
Try it out. Put your x,y and z into the two original plane equations. At t=0 you get (5/3,0,0). That's not on either of the original planes, is it?
Ah i do notice that, but
x+2y+3z=4x+5y+6z-5
if i plug them into that those points solve the equation, which is the x,y,z such that those two planes are equal, or is that me failing at winging a problem?
If you mix up two planes you get a third plane. A line in that plane may or may not be in either of the two planes you started with. I admire your spirit of winging it, but when you scamble the two planes, you loose information.
so i just needed to restrict that plane to a set of values that lie in both planes. so I am just wondering what exactly did i do by setting the two planes equal to each other? i notice i get the same result if i subtract equation 1 from equation 2, so did i just subtract the two planes by setting them equal? I am confused as to what that actually does
Yeah, you effectively just subtracted one equation from the other. This gives you a new plane in which the line of intersection lies, so you're just finding the equation of a plane rotated about that line.
Try a simpler example. Take the planes x=0 and z=0. They intersect along the line (0,t,0). Subtract them and get x-z=0. That's a different plane. Still contains (0,t,0) though. Adding and subtracting the plane equations isn't getting you any closer to finding the intersection. I think you'd better stick with the normal and cross product method.
okay thanks guys for all your help. i understand this a lot better now
  • · Replies 22 ·
  • · Replies 17 ·
