Parametric to Polar Conversion
  • Thread starter Thread starter Zach Knight
    Parametric Polar
3 replies · 11K views
Zach Knight
Convert the two equations x=x(t) and y=y(t) to a polar equation of the form r=r([tex]\theta[/tex])
x=r*cos([tex]\theta[/tex])
y=r*sin([tex]\theta[/tex])
r[tex]^{2}[/tex]=x[tex]^{2}[/tex]+y[tex]^2[/tex]
Perhaps I'm over-thinking this, but in order to eliminate the parameter t, I solved one of the two parametric equations, say x(t), for t, giving an equation t=t(x). I then substituted this equation into y(t), giving y=y(t(x)). Afterward, I used the identities listed above to convert y to r. Is this valid? Is there a way to do this without having to invert one of the functions?
It doesn't seem valid to me. For one thing, when you solve for t in terms of x, you are finding the inverse of the original function, which may or may not exist. For example, if x = f(t) = t2 + 3, f is not one-to-one, so doesn't have an inverse.
The usual approach is to eliminate the parameter t, and then replace x and y using the identities you show.
For example, if x = t and y = t2, x2 - y = t2 - t2 = 0,
so r2cos2(theta) - rsin(theta) = 0.
This is equivalent to rcos2(theta) - sin(theta) = 0, or r = sin(theta)/cos2(theta), so here we have r as a function of theta. Eliminating one factor of r is legitimate in this case since there is at least one value of theta for which sin(theta)/cos2(theta) = 0 (namely theta = 0, and others), so we haven't lost any solutions by getting rid of the factor of r.
There is one conversion formula that you didn't show, that is sometimes useful: theta = tan-1(y/x).
But where are your parametric equations you want to convert to polar coordinates? [itex]x= rcos(\theta)[/itex] and [itex]y= r sin(\theta)[/itex] are NOT parametric equations- they are true for all points in the plane.
The thing is, I don't have the parametric equations; I'm trying to find them via a differential equation. I'm trying to formulate
[tex]\frac{d^2\vec{r}}{dt^2}=\frac{-MG}{|r|^3}\vec{r}[/tex]
in terms of [tex]\theta[/tex] because the only way I could find to solve the above equation was to assume [tex]|r|[/tex] was a constant. I think I have it now though. I rewrote the problem in terms of the unit vector
[tex]\hat{r}=cos(\theta)\hat{i}+sin(\theta)\hat{j}[/tex]
and got
[tex](\frac{d^2r}{dt^2}-r(\frac{d\theta}{dt})^2)\hat{r}+(2\frac{dr}{dt}\frac{d\theta}{dt}+r\frac{d^2\theta}{dt^2})\frac{d\hat{r}}{dt} = \frac{-MG}{r^2}\hat{r}[/tex],
a differential equation I think I can actually solve.
Sorry if any of the math or notation is wrong; I haven't had a calculus class yet, so my education isn't very formalized yet.
