Parametrised Circle Trajectory: Particle in x≤0 Half-Plane
  • Thread starter Thread starter Poetria
    Circle
The discussion centers on the trajectory of a particle defined as a semi-circle in the x≤0 half-plane, which is ultimately deemed incorrect. Participants note that common parameterizations of the unit circle, such as x(t)=cos(t) and y(t)=sin(t), yield different paths and directions. The correct trajectory should actually be a semi-circle in the x≥0 half-plane. Understanding the directionality of these parameterizations is crucial, especially in contexts like line integrals. The confusion arises from misinterpreting the problem's requirements and the correct placement of the semi-circle.
Poetria
There is a unit circle, where x(t)=sin(t), y(t)=cos(t)
0≤t<pi
x^2+y^2=1
The trajectory of a particle is a semi-circle contained in the x≤0 half-plane.
Well, this is somewhat weird. I have come across examples with x(t)=cos(t), y(t)=sin(t) and not the other way round.
By the way, my answer is wrong but I don't know why. This is probably silly. :(
Those parametrizations are just different parametrizations of the unit circle.
Likes Poetria
Those are actually different paths going in different directions. For ##t \in (0,\pi)##, (cos(t),sin(t)) stays in the upper half-plane and goes counter-clockwise from (1,0) to (-1,0). The counter-clockwise, starting at (1,0), parameterization occurs often in complex analysis and elsewhere, but usually goes all the way around the circle.
(sin(t),cos(t)) stays in the right half-plane, starts at (0,1) and goes in a clockwise direction to (0,-1). That is an unusual parameterization.
When line integrals are studied, the correct direction of the path is critical. And the ends of the paths are always critical.
  • Love
Likes Poetria
Ok, I got it. Many thanks. But why is my answer wrong then? :rolleyes:
Great, I understand everything now. Many thanks. 😍
Hard to say because you never told us what the question actually was!
Likes Poetria
"The trajectory of a particle is a semi-circle contained in the x≤0 half-plane." - this one is wrong. There were several options in this problem.
The right one: The trajectory of a particle is a semi-circle contained in the x≥0 half-plane.
Thank you very much. I know this is easy but I was confused.
Likes benorin and Delta2
9K
  • · Replies 21 ·
