Partial derivative query - guidance needed
12 replies · 2K views
petertheta
I have a question but have not seen an example or find anything in my textbooks so would love some advice on how to understand the problem.
Its a theory question on partial derivatives of the second order...
T=T(x,y,z,t) with x=x(t), y=y(t), z=z(t).
Find the second derivative of T wrt t
So, first find the first derivative to give:
[tex]\frac{dT}{dt} = \frac{\partial T}{\partial x}\frac{dx}{dt} +\frac{\partial T}{\partial y}\frac{dy}{dt}+\frac{\partial T}{\partial z}\frac{dz}{dt}+\frac{\partial T}{\partial t}[/tex]
So I know the second derivative will be:
[tex]\frac{d}{dt}\left(\frac{dT}{dt}\right)[/tex]
So now my question. How do i take derivatives of products of mixed derivatives and write it in a correct manner, albeit a theoretical one.
Your help means a lot.
PT
PT
Your dT/dt is a sum of four terms. Do you agree that you can take another d/dt of each term separately, then add the results? So, look at the first term
[tex]\frac{\partial T}{\partial x} \frac{dx}{dt}.[/tex] This has the form G(x,y,z)*v(t), where
[tex]G = \partial T/\partial x, \: v = dx/dt \text{ and } x = x(t), \:y = y(t), \:z = z(t).[/tex] Just apply your (d/dt) rule to G*v. Similarly for the other terms.
RGV
Thanks RGV. So would the first "set" be:
[tex]\frac{\partial T}{\partial x}\frac{dx}{dt}+\frac{dx}{dt}\frac{dx}{dt}[/tex]
or better still...
[tex]\frac{\partial T}{\partial x}\frac{dx}{dt}+\frac{d^2x}{dt^2}[/tex]
OK. I'm struggling but I think this might be it...
[tex]\frac{\partial G}{\partial x}\frac{dx}{dt}+G\frac{dx}{dt}\frac{dx}{dt}[/tex]
Nope. It'll probably help to write out the variable dependencies explicitly. Applying the product rules gives
$$\frac{d}{dt}[G(x,y,z,t)v(t)] = \left(\frac{d}{dt} G(x,y,z,t)\right) v(t) + G(x,y,z,t)\frac{dv}{dt}.$$ Now look at your expression for dT/dt in your original post. You'll get the same sort of thing for dG/dt. I'll let you take it from here.
I get a different result everytime i try :(
OK. Third time lucky! For the first "element"
[tex]\frac{\partial G}{\partial x}\frac{dx}{dt}v(t)+G\frac{dv}{dt}[/tex]
Then substitute G and v for what is know...
[tex]\frac{\partial G}{\partial x}\frac{dx}{dt}\frac{dx}{dt}+\frac{\partial T}{\partial x}\frac{d}{dt}v[/tex]
So
[tex]\frac{\partial^2 T}{\partial x^2}2\frac{dx}{dt}+\frac{\partial T}{\partial x}\frac{d^2x}{dt^2}+...[/tex]
Im only writing for the very first term from the first derivative to see if I'm on the right track how does it look??...
Sorry that was a typo for 2 times dx/dt
Ahh, I think I see your point. For the first term in the first derivative, when taking the second derivative I must do it for x,y,z and t. The the same for the second term... etc, etc... Is this correct??
thats going to be a big answer! OK. So here we go just for the first term of the first derivative...
[tex]\frac{\partial^2T}{\partial x\partial x}\frac{dx}{dt}\frac{dx}{dt}+\frac{\partial T}{\partial x}\frac{d^2x}{dt^2}<br /> +<br /> \frac{\partial^2T}{\partial x\partial y}\frac{dy}{dt}\frac{dx}{dt}+\frac{\partial T}{\partial x}\frac{d^2x}{dt^2}<br /> <br /> +<br /> \frac{\partial^2T}{\partial x\partial z}\frac{dz}{dt}\frac{dx}{dt}+\frac{\partial T}{\partial x}\frac{d^2x}{dt^2}<br /> +<br /> \frac{\partial^2T}{\partial x\partial t}\frac{dt}{dt}\frac{dx}{dt}+\frac{\partial T}{\partial x}\frac{d^2x}{dt^2}...<br /> <br /> <br /> <br /> [/tex]
Almost. It should be
$$\left(
\frac{\partial^2T}{\partial x^2}\frac{dx}{dt} +
\frac{\partial^2T}{\partial y\partial x}\frac{dy}{dt} +
\frac{\partial^2T}{\partial z\partial x}\frac{dz}{dt} +
\frac{\partial^2T}{\partial t\partial x}\right)\frac{dx}{dt} +
\frac{\partial T}{\partial x}\frac{d^2x}{dt^2}$$ The last term only appears once.
