Partial derivatives (related rates)
This discussion focuses on calculating the rate at which the distance between two cars, A and B, is changing as they approach an intersection using partial derivatives and the chain rule. Car A is 0.3 km from the intersection traveling at 90 km/h, while Car B is 0.4 km away traveling at 80 km/h. The correct application of the chain rule leads to a rate of -118 km/h, indicating that the distance between the cars is decreasing. The confusion arises from the interpretation of the signs in the derivatives, where negative values are used to represent the decreasing distances as the cars approach the intersection.
  • Understanding of the Pythagorean theorem
  • Knowledge of chain rule in calculus
  • Familiarity with partial derivatives
  • Basic concepts of related rates in calculus
  • Study the application of the chain rule in related rates problems
  • Learn about the geometric interpretation of partial derivatives
  • Explore examples of related rates involving multiple moving objects
  • Review the concept of negative rates in the context of distance and speed
Students studying calculus, particularly those focusing on related rates and partial derivatives, as well as educators seeking to clarify these concepts in practical scenarios.
evilpostingmong
Car A is going north, car B is going west, each are approaching an intersection on their respective highways. At an instant, car A is .3km from its intersection while car B is .4 km from it's intersection. Car A travels at 90km/h while car B travels 80km/h. Find the rate at which the distance between them is changing at that moment.
Pythagorean theorem x^2+y^2=z^2
chain rule of partial derivatives.
z=sqrt(x^2+y^2) so by the chain rule (differentiatiing with respect to x*90+differentiating with respect to y*80) I get
90y/sqrt(x^2+y^2)+80x/sqrt(x^2+y^2) and setting y=.3km and x=.4lkm I get 118km/h
but the book used negative values and got -118km/h. It used -80 and -90km/h for its dz/dx's and dz/dy's. Why did it do this?
Why partial derivatives? The only independent variable here is t.
It would be much simpler to use z2= x2+ y2 so that
2z\frac{dz}{dt}= 2x\frac{dx}{dt}+ 2y\frac{dy}{dt}
I have no idea what you mean by "differentiatiing with respect to x*90+differentiating with respect to y*80". What do "x*90" and "y*80" represent physically in this problem? If x and y are distance as they appear to be then "x*90" and "x*80" would have units of km2 per hour and I don't reconize that as any physical quantity.
You never did say what "x", "y", and "z" represent. I guess that x is the distance from the intersection to car B since you take x= 0.4 km at the given instant. If that is correct, then since car B is getting closer to the intersection as time progresses, x is a decreasing function of t and its derivative is negative: -80 km/hr. Similarly, dx/dt= -90 km/hr.
also, your text did NOT use "-80 and -90km/h for its dz/dx's and dz/dy's" because the 80 and 90 here are speeds in km/hr while dz/dx and dz/dy are "km/km" and so dimensionless. Your text is using -80 and -90 for dx/dt and dy/dt.
Oh sorry lol I meant to say dy/dt and dx/dt for the speeds. Yeah even though
partial derivatives are not needed, I used them anyway because I'm doing problems from
the chain rule for partial derivatives chapter. I came up with the same answer, the only problem was the signs. Yes x y and z represent the distance from the intersections, you're right.
