Partial differentiation problem, multiple variables (chain rule?)
The discussion revolves around finding the partial derivative of the function z = x² + 2y² with respect to θ, while keeping x constant. The initial approach involved substituting y = r sin θ and simplifying, but led to confusion regarding the correct derivative. Participants clarified that r is not independent of θ, which necessitates using the product rule for differentiation. Ultimately, the correct solution simplifies to 4r² tan θ, highlighting the importance of proper application of differentiation rules and substitutions. The conversation emphasizes the need for careful handling of variables when applying the chain rule in multivariable calculus.
bawbag
if z = x2 + 2y2 , x = r cos θ , y = r sin θ , find the partial derivative
\left(\frac{\partial z}{\partial \theta}\right)_{x}
z = x2 + 2y2
x = r cos θ
y = r sin θ
The textbook says that the equation should be re-written to include only the variables θ and x, and then differentiated with respect to θ.
Substituting y = r sin θ :
z = x2 + 2r2 sin2 θ
then \left(\frac{\partial z}{\partial \theta}\right)_{x} = 4r2sin θ cos θ
However the solutions in the book give
\left(\frac{\partial z}{\partial \theta}\right)_{x} = 4r2 tan θ
What am I missing here?
Thanks in advance.
z = x2 + 2y2
x = r cos θ
y = r sin θ
z = x2 + 2r2 sin2 θ
Thanks in advance.
You need to differentiate y^2 = r^2 \sin^2 \theta using the product rule: r is not independent of \theta, since <br /> r = \frac{x}{\cos \theta}
Likes 1 person
Thanks! I used the product rule to differentiate, but I still think I'm missing something. My working is as follows:
z = x2 + 2r2 sin2 θ
\left(\frac{\partial z}{\partial \theta}\right)_{x} = \frac{\partial}{\partial \theta}2r^{2}sin^{2}\theta
= 4r\frac{\partial r}{\partial \theta}sin^{2}\theta + 2r^{2}2sin\theta cos\theta (chain rule for dr/dθ)
since r = \frac{x}{cos \theta}, \frac{\partial r}{\partial \theta} = \frac{-x sin \theta}{cos^{2} \theta}
giving -4r \frac{x sin \theta}{cos^{2} \theta} sin^{2} \theta + 4r^{2} sin \theta cos \theta
I can replace x with r / cos θ, but I don't see how it reduces to the given solution of 4r2 tan θ.
Thanks again
z = x2 + 2y2
x = r cos θ
y = r sin θ
z = x2 + 2r2 sin2 θ
Thanks in advance.
You are missing the fact that ##x## is held constant. One way to do it is:
dz = 2 x\, dx + 4 y \,dy\\<br /> dx = \cos(\theta) \, dr - r \sin(\theta)\, d \theta\\<br /> dy = \sin(\theta)\, dr + r \cos(\theta)\, d \theta
But ##dx = 0 \Longrightarrow dr = r \tan(\theta) \, d \theta##, so
dy = r \sin(\theta)\tan(\theta)\, d \theta + r \cos(\theta) \,d \theta<br /> = r \left( \frac{\sin^2(\theta)}{\cos(\theta)} + \cos(\theta)\right)\, d \theta<br /> = \frac{r}{\cos(\theta)}\, d \theta
Thus
dz = 4 y dy = 4 r \sin(\theta) (r/\cos(\theta)) \,d \theta = 4 r^2 \tan(\theta) \, d \theta
The partial ##(\partial z/\partial \theta)_{x} ## is the coefficient of ##d \theta## in the above.
Likes 1 person
z = x2 + 2r2 sin2 θ
The derivative of u^{-1} with respect to u is -u^{-2}. The derivative of \cos \theta with respect to \theta is -\sin \theta. The two minus signs cancel.
You can't, but you can replace x with r \cos \theta and do some trigonometric simplifications; the first step is to express everything in terms of sines and cosines.
Likes 1 person
z = x2 + 2r2 sin2 θ
Thanks again
Try saying z = x2 + 2\frac{x^2}{cos^2θ}sin2θ = x2(1 + 2tan2θ)
Now with this for z you can perform \left(\frac{\partial z}{\partial \theta}\right)_{x} quite easily.
Hint* Remember, that after you perform the derivation to look for anywhere you can make a substitution to remove 'x'.
Likes 1 person
That was a typo, my bad. So after sorting the minus sign, I'm left with essentially what I had before, but I can't see anyway of reducing 4r^{2} tan \theta sin^{2} \theta + 4r^{2} sin \theta cos \theta to 4r^{2} tan \theta without ending up with a huge mess.
Sorry for being dense :P
Figured it out. Thanks guys. Turns out I laid it out the way jaytech said, but didn't use the product rule properly so I abandoned that method and tried it another way, which lead to that whole mess. Whoops!
Thanks to everyone who helped!
You should try the steps I previously mentioned. Then reflect on why it works..
\sin \theta \cos \theta = \tan\theta \cos^2 \theta
Likes 1 person
I did use the steps you suggested, jaytech. As for why it works, I imagine that I should be able to reach the solution from any starting point, with proper application of the chain rule/product rule, but arranging it as you suggested means I can skip over a lengthy simplification process after the operation. Any other insight you care to offer? :)
