Particle decay branching process: P(x2>0) and conditional probability
  • Thread starter Thread starter Fatimah202
    Probability
16 replies · 3K views · last reply
Fatimah202
An imaginary particle can decay in 0, 1 or 2 particles of the same kind with probabilities 1/4, 1/2 and 1/4, respectively. Beginning with one particle, we denote xi the number of particles in the ith generation. Determine:
a. P(x2 >0)
b. The probability that x1 = 2, given that x2 = 1.
let say event A : the particle decay to 0 particle P(A)=1/4
event B: the particle decay to 1 particle P(B)=1/2
event C: the particle decay to 2 particles P(C)=1/4
[/B]
the conditional probability :
P(A|B)= P(A∩B) /P(B)
For part a:
I am not sure that I understand the question very well .. is it mean by P(x2 >0) the second generation (x2) can decay to 1 or 2 particles .. if yes shall I do this:
P(B∩C) =P(B)×P(C)
=1/2 × 1/4 = 1/8 =13%
For part b:
P(x1|x2) = ?
is it equal to P(B|C) ??please give me a hint .. I need to solve this by hand and then I can compute it
thank you so much :)
I would say this is an ideal problem to use a probability tree. Your notation using A, B and C, doesn't really help you given that there are different generations of these events.
I think you've misinterpreted the problem. The initial particle must be the 0th generation (I assume). So, the first generation is what it decays into.
https://fly.cloud.photobox.com/2984919587ea968d6b9e99fdd1b96c87d958717a3c978173f83c89a622c049a69cc2da81.jpg
is this correct ?
I think I should not calculate the zero particle ,, right ?
Fatimah202 said:
is this correct ?
That's a good approach. Remember that if 2 particles are created in the first generation, then both of these will decay independently in the second generation. So, you need a bit more work on the case where ##x1 = 2##
how about this ?
and for part b :
P= 25%
PeroK .. thank you very much :)
Fatimah202 said:
how about this ?
and for part b :
P= 25%
I'm not sure how you get ##P(x2 > 0) = 1##
There are three ways you can end up with 0 particles:
##x1 = 0##
##x1 = 1## and ##x2 = 0##
##x1 = 2## and ##x2 = 0## (for both particles)
For part b, how do you get 25%?
x1=0x1 = 0
x1=1x1 = 1 and x2=0x2 = 0
x1=2x1 = 2 and x2=0x2 = 0 (for both particles)
well, the problem ask for the probability of getting number of particles in the second generation more than zero ... not equal to zero right ?
so I sum up all the probabilities of getting 1 particle and 2 particles in second generation .. I will highlight the path in the attached photo
I get P=1 when I sum all the probabilities even with getting zero particles .. but now if I remove them I get P=0.75
##P(x1 = 0)## = 0.25
Hence ##P(x2 = 0) > 0.25##
You must have made a mistake adding up.
why you are looking for the probability of getting zero particle ?
for part b .. I would say that when x1=2 and x2=1
p= (0.25 * 0.5) +(0.25 *0.5) = 0.25
right ?
right ?
I don't understand that calculation. The first thing you need is ##P(x2 = 1)##. What do you get for that?
is the tree that I made wrong ?
I will explain the calculations:
p(x1=2) = 0.25
p(x2=1)= 0.5
but because the first generation get 2 particles I will multiply it by 2
2(0.25*0.5) = 0.25
where is the mistake exactly ?
p(x1=2) = 0.25
p(x2=1)= 0.5
2(0.25*0.5) = 0.25
That's just not the correct approach. And, when you did your tree you forgot to combine probabilities in the case where x1 = 2.
Given x1 = 2, you have:
##P(x2 = 0) = (1/4)(1/4) = 1/16##
##P(x2 = 1) = 2(1/4)(1/2) = 1/4##
Etc. All the way to ##P(x2 = 4)##
In the tree, you need to factor in the probability of 1/4 that ##P(x1 = 2)##
In any case, ##P(x2 = 1) \ne 0.5##
cool !
that take us to say p(x2=1) = 1/4
is not like this ?
right ?
Fatimah202 said:
cool !
is not like this ?
That's not right. There is a formula for conditional probabilities, but let me show you how I think about it. In this case we want ##P(x1 = 2 | x2 = 1)##
First, we identify all the tree branches that result in ##x2 = 1##. There are two of them:
1) x1 = 1 -> x2 = 1 (this has a probability of 1/4 = 4/16).
2) x1 = 2 -> x2 = 1 (this has a probability of 1/16)
Every 16 times we do the experiment, we wil get x2 = 1 on average 5 times: 4 times from the first branch (where x1 =1) and 1 time from the second branch (where x1 = 2).
So, given that x2 = 1, the probability is 4/5 that x1 =1 and only 1/5 that x1 = 2.
Note that in this case, the conditional probability was going "backwards". The question is not: given that x1 = 2, what is the probability that x2 = 1. That is simpler, with the conditional probability going "forwards".
You have to be able to think though conditional probabilities both ways, as it were. For example, here are two different questions:
a) Given that it's raining today, what's the probability that it will be raining tomorrow.
b) Given that it's raining today, what is the probability that it was raining yesterday (assumning you don't know!).
sorry, I forget the conditional probability :(
P(x1=2|x2=1) =P(x1=2 ∩x2=1) / P(x2=1)
P(x1=2 ∩x2=1) = 1/16
P(x2=1)= 5/15
P(x1=2|x2=1) = 1/5
correct?
________________
you divide by two instead of multiply !
I was double it and get P= 1/4 instead of 1/16 !
I calculated the total probability of that sequence of events. You were calculating the conditional probability of the 2nd event given the first. It's important to understand which one is needed.
You need a new problem now to test whether you understand these sort of problems. You've got the right answer now, but after a lot of attempts!
thank you very much
actually I was working on a computing and I forget some details on the statistical basics .. I didn't take a course on the probabilities
tank you :)
