Particle falling radially into a black hole
1 reply · 1K views · last reply
Cythermax
New poster has been reminded to show their work on schoolwork problems
Attached it below
Not sure which equations necessary here.
I've been stuck starting anywhere with this. I need to finish this class for graduation and i'd like a safety net of a passing grade with this.
  • Text of a physics problem: a particle of mass m falls radially toward a Schwarzschild black hole of mass M with energy per unit mass E = 0.95; parts (a) to (d) ask for proper time between radii, coordinate-basis four-velocity components at r = 2.001 M, and the redshift of a photon sent radially to a stationary observer.
Well, do you know what the Schwarzschild metric is? In Schwarzschild (spherical) coordinates, if a particle starts at the point ##r, \theta, \phi## at time ##t## and travels a small distance to the point ##r+\delta r, \theta + \delta \theta, \phi + \delta \phi## by time ##t+\delta t##, then the the change in proper time ##\delta \tau## satisfies:
##(\delta \tau)^2 = (1 - 2GM/(c^2 r))^{-1} (\delta t)^2 - (1 - 2GM/(c^2 r)) (\delta r)^2 - r^2 \delta \theta^2 - r^2 sin^2(\theta) (\delta \phi)^2##
You have to start with that as a "relevant equation".
