Particle in a circular path due to magnetic field
The discussion revolves around a problem involving a particle, specifically a proton, moving in a circular path due to a magnetic field. Participants are examining the relationship between kinetic energy, potential difference, and the resulting velocity and radius of the particle's path.
  • Mixed
  • Participants explore the equations for velocity and radius in the context of kinetic energy and electric potential. Questions arise regarding the interpretation of variables, particularly the charge of the proton and the conversion of energy units from electron-volts to joules.
There is ongoing clarification regarding the correct use of equations and units. Some participants have offered insights into the relationships between energy, charge, and potential, while others express confusion about the conversions and the definitions of terms used in the equations.
Participants are navigating the complexities of unit conversions and the implications of using different forms of energy in their calculations. The discussion reflects a mix of correct and incorrect assumptions about the relationships between electric potential, kinetic energy, and the resulting motion of the proton.
fight_club_alum
What will be the radius of curvature of the path of a 3.0-keV proton in a perpendicular
magnetic field of magnitude 0.80 T?
a . 9.9 mm <-- answer
b. 1.1 cm
c. 1.3 cm
d. 1.4 cm
e. 7.6 mm
v = sqrt( (2 * q * potential) / mass)
mv/bq = r
v = sqrt( (2 * charge of proton * 3000/e) / (mass of proton))
v = 1.893986024 x 10^`15
r = ( (mass of proton) * (velocity) ) / ((magnetic field) * (charge of proton))
r = 24715769.68 m
Anyone please help
Check your units!
fight_club_alum said:
Relevant Equations: v = sqrt( (2 * q * potential) / mass)
mv/bq = r
r = 24715769.68 m
Anyone please help
What is 'e' in the formula for the speed? What is the unit of speed you got?
e is the charge of the electron on the constant list in the calculator, which is the same as the proton without the sign
Why did you divide by it?
to convert from ev to v. Am I correct?
The answer comes out if I convert the ev to joule and work normally using the kinetic energy equation 1/2 m v^2 = E
But what is the mistake when I use the other equation?
No. The conversion happened when you multiplied the potential difference with q.
1 eV = Potential difference multiplied by the elementary charge e (which is equal to q in your case)
I'm sorry but I don't understand
is v = sqrt( (2q(potential)/ mass)
If yes
isn't ev/electron charge = volt
Thank you
That equation is wrong as you multiplied and divided the eV-s by the elementary charge.
So, the equation should be v = sqrt( (2 * q * ev ) / mass)
If yes
Thank you
The equation 'v = sqrt( (2q(potential)/ mass)' is wrong. Instead of 'potential' it must be energy, but you have the energy in eV-s here, which converts to joules, if you multiply the potential value (3000) with the electronic charge.
If an electron or proton travels across a potential difference of U Volts, it gains e U kinetic energy. But we say that it gained U eV energy. So we measure energy by the potential difference which would accelerate the electron/proton to that energy.
thank you
so the right one should be
v = sqrt ( (2 * e * (3000e) / (Mass of proton) ) <--- e is just the charge of the proton
It is not wrong, but eV is not a unit of electric potential, it is an energy unit, ie, the value given is the charge multiplied by the accelerating potential. In fact, there is no reason to even talk about an accelerating potential here as it does not matter how the proton was accelerated. The only thing that matters is that it has a given kinetic energy.
thank you
No. ##energy=0.5 mv^2 = 3000e##
So ## v=\sqrt{2*3000e/m}##
When I do this
v = sqrt ( 2 * e * 3000/ mass of the proton) <---- where e is the charge of the proton and 3000 is the ev I get the right answer
So normally I should use (ev) not v
great! thank you so much
Sorry if I confused the whole forum
When I do this
Yes, you get the speed from the kinetic energy, and you can measure energy in eV units, but it should be converted to joules, by multiplying the electron-volts by e. Here e is the elementary charge, not the charge of the particle in question.
If it was an oxygen ion with charge 2e, and energy 3000 eV, the energy in joules would be 3000*e again.
Thank you
but
if I did this to convert ev to j
sqrt(2 * e * (3000e) / mass) <---- where e is the charge of a proton and 3000e is the ev to joule conversion
I get the wrong answer
Thank you
but
You multiplied by e twice. v=sqrt(2*energy/mass) and energy (in joules) = e*energy (in electron-volts)
Oh, I see what I've been doing
Thank you and sorry for taking too long
You are welcome :smile:
  • · Replies 31 ·
