Particle in an electric field- formulae suggestions.
The discussion revolves around a particle of charge q and rest mass m_0 being accelerated in a uniform electric field E. Participants are exploring the relativistic expression for the speed of the particle after a time t, as well as relevant equations and concepts related to relativistic motion and forces.
  • Participants discuss various equations related to kinetic energy and electric force, attempting to rearrange and substitute them. Questions arise about the physical meaning of certain expressions and the implications of the direction of the applied force.
The discussion is active, with participants providing hints and questioning each other's reasoning. There is an exploration of different interpretations of relativistic force equations and their applications to the problem at hand. Some guidance has been offered regarding the relationship between momentum and velocity in relativistic contexts.
Participants note the lack of information regarding the direction of the applied force, which raises questions about which relativistic force expression to use. There is also mention of differing opinions on the concept of relativistic mass.
Alpha&Omega
1. A particle of charge q and rest mass [tex]m_0[/tex] is accelerated from rest at t=0 in a uniform electric field of magnitude E. All other forces are negligible in comparison to the electric field force. Show that after a time t the relativistic expression for the speed of the particle is:
[tex]v=\frac{c}{\sqrt{1+\frac{m_0^2c^2}{q^2E^2t^2}}}[/tex]
I think the equations relevant here have got to be [tex]E_k=(\gamma-1)m_0c^2[/tex] and [tex]E=\frac{F}{q}[/tex].
I've tried rearranging the above equations and substituting them into each other but I can't get anything good. Does anyone know any other useful equations that I might be able to use?
Hi Alpha&Omega! :smile:
(how come you have two different names? :confused:)
Hint: with that v, what is (v/c)/√(1 - v2/c2) ? :wink:
I felt insecure. XD
Do you mean as a physical quantity?
I would just do this:
[tex]\frac{\frac{v}{c}}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
[tex]\sqrt{\frac{\frac{v^2}{c^2}}{1-\frac{v^2}{c^2}}[/tex]
[tex]\sqrt{\frac{1}{1-\frac{v^2}{c^2}}-1[/tex]
Is this what you meant? =S
No :biggrin:, I meant what is (v/c)/√(1 - v2/c2) if [tex]v=\frac{c}{\sqrt{1+\frac{m_0^2c^2}{q^2E^2t^2}}}[/tex] ? :wink:
Ah, darn. Let me see:
[tex]\frac{{\frac{c}{\sqrt{1+\frac{m_0^2c^2}{q^2E^2t^2}}}}{c}}{\sqrt{1-\frac{(\frac{c}{\sqrt{1+\frac{m_0^2c^2}{q^2E^2t^2}}})^2}{c^2}}}[/tex]
[tex]\frac{{\frac{c^2}{\sqrt{1+\frac{m_0^2c^2}{q^2E^2t^2}}}}}{\sqrt{1-\frac{(\frac{c^2}{{1+\frac{m_0^2c^2}{q^2E^2t^2}}})}{c^2}}}[/tex]
[tex]\frac{{\frac{c^2}{\sqrt{1+\frac{m_0^2c^2}{q^2E^2t^2}}}}}{\sqrt{-\frac{m_0^2c62}{q^2E^2t^2}}}[/tex]
Ummm, am I doing it correctly? I've got a complex number as the denominator! =S
uhhh? whadya do? :confused:
should be qEt/m0c :wink:
magic!
This may sound weird, but how did you know to use [tex]\frac{\frac{v}{c}}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]?
Because I knew that m0(v/c)/√(1 - v2/c2) is the … ? :smile:
(btw, it would have save a lot of paper and time if you'd written X, say, instead of that fraction! :wink:)
The momentum divided by c?
So if momentum is MeV/c then in this equation we have MeV/c2 which is the mass!
(I know it would have saved trees, but for some reason I decided to do it this long and complicated way =D).
So I have to work from this equation to the equation posted in the thread.
I just tried it and I noticed that the question doesn't mention whether the applied force is parallel to the x-axis or perpendicular to it. Which expression for relativistic force should I use?
Yup! :biggrin:
So the question is asking you to prove that after time t the momentum is qEt …
what principle of physics would you use to do that? :wink:
uhh? :confused: the x-axis is wherever you want it to be
tiny-tim said:
Yup! :biggrin:
Would it be an integral of an expression for the force with respect to time?
In my book it has two expressions for relativistic force. One is [tex]F=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}ma[/tex] if it's perpendicular to the x-axis and the other is [tex]F=\frac{1}{(1-\frac{v^2}{c^2})^\frac{3}{2}}ma[/tex] if the force is in the same direction as the field.
I was thinking more along the lines of "Force = …"
(work backwards from the answer! :wink:)
ah …
so the velocity will always be in the same direction as E :smile:
btw, I don't normally approve of "relativistic mass", but in this case I find it easier to remember the equations as
Fperp = mrela
Fpara = mrela/(1 - v2/c2)
so I remember the perpendicular force equation as being the same as Newton's :wink:
  • · Replies 17 ·
