Particle in linear accelerator
In summary, the conversation discusses the calculation of the force applied to an electron undergoing linear acceleration due to a uniform electric field and the calculation of the instantaneous radiated power. The force is calculated using the formula F = E_0*e, and the radiated power is calculated using the relativistic formula P(t') = (2/3)*(e^2)*(dE/dx)^2*(gamma^6). The Larmor formula can also be used, but only for non-relativistic motion. For circular motion, the radiated power formula is P(t') = (2/3)*(e^2)*(|dv/dt|^2)*(gamma^4).
_Matt87_
An electron ([itex]e=1.6x10^(-19)[/itex] Coulomb) of total energy 10.22 MeV ([itex]\gamma[/itex] about 20) is undergoing linear acceleration due to application of a uniform electric field of strenght [itex]E_0=1000 MV/m[/itex]
a)how large is the applied force, in Newton?
b) Calculate the instantaneous radiated power in watts
i think that for b) it would be : [itex]P=\frac{2}{3}*\frac{e^2}{m^2*c^3}*(\frac{dE}{dt})^2[/itex]
but not so sure after all
a) F=[itex]E_0[/itex]*e ?
For (a), I agree, I think it's that simple.
For (b), the Larmor formula does not apply because this is so relativistic (gamma = 20!). You will have to use the relativistic formula; see section 8.2 here:
http://physics.usask.ca/~hirose/p812/notes/Ch8.pdf
Note that getting acceleration from force (Newton's second Law) must be corrected for relativity, you can't just use F = ma.
so for linear acceleration:
[tex]P(t')=\frac{2}{3}\frac{e^2\dot{\beta^2}}{3c}\gamma^6[/tex]
right? it's from 8.3 in the pdf you sent.
Although at the very end of that chapter there is still the same equation I wrote earlier. And it says 'Note that the radiation power due to linear
acceleration is independent of the particle energy or the relativity factor [itex]\gamma[/itex]'
so what now then?
and what's for circulair motion ?:
[tex]P(t')=\frac{2}{3}\frac{e^2|\dot{v}|^2}{c^3}\gamma^4[/tex] ?
I'm looking at Jackson v3 eqns. 14.26-14.28 (hopefully you have a copy), they derive the formula as in the PDF as being dependent on the acceleration, then write acceleration as dp/dt, then write dp/dt as dE/dx, which they interpret as being entirely from the external field. In other words, the acceleration of the particle is entirely caused by the external fields.
So does it depend on the particle energy? No, only on the particle's acceleration.
Does it depend on gamma? No, it depends on dE/dx. BUT, if you try to write dE/dx in terms of dbeta/dt, then the factor of gamma^6 reappears. This is irrelevant in your problem (as in real experiments), as you have dE/dx given.
So I agree with you that the Larmor formula will give you the right answer. But, as presented in Griffiths for example, it only applies to non-relativistic motion -- if you want to use it for relativitistic particles, you have to explain why it is valid.
As for circular motion, this is correct in terms of the particle acceleration -- if you write it in terms of dE/dx = dp/dt (Jackson 14.47), it will depend only on external parameters as before -- except for the factor of gamma^2, which cannot be gotten rid of. This is why we can't do e-e+ collisions in the LHC for example ("synchrotron radiation"); we need an ILC.
Yes, you are correct in your attempt at a solution for part a. The applied force on the electron can be calculated using the equation F = qE, where q is the charge of the particle and E is the electric field strength.
b) Your attempt at a solution for part b is also correct. The instantaneous radiated power can be calculated using the Larmor formula, which is P = (2/3)*(q^2/m^2)*c^3*(dE/dt)^2, where q is the charge of the particle, m is its mass, c is the speed of light, and dE/dt is the rate of change of the particle's energy. In this case, the energy of the particle is changing due to the applied electric field, so dE/dt is equal to qE_0, where E_0 is the electric field strength. Plugging in the values given in the problem, we get P = (2/3)*(1.6x10^-19)^2/(9.11x10^-31)^2*(3x10^8)^3*(1000x10^6)^2 = 1.05x10^-10 watts. This is a very small amount of power, which is expected for a single particle undergoing linear acceleration.
Related to Particle in linear accelerator
What is a particle in a linear accelerator?
A particle in a linear accelerator refers to a subatomic particle, such as an electron or proton, that is accelerated to high energy levels and used for various purposes in scientific research and medical treatments.
How does a particle in a linear accelerator work?
A particle in a linear accelerator is accelerated by using electromagnetic fields to push it along a linear path. As the particle passes through the accelerator, it gains energy from the fields until it reaches the desired speed and energy level.
What is a linear accelerator used for?
A linear accelerator has several uses, including accelerating particles for scientific experiments, producing high energy X-rays for medical imaging and cancer treatments, and powering particle accelerators for nuclear research.
Why is a linear accelerator important in scientific research?
A linear accelerator allows scientists to study the behavior and properties of particles at extremely high energies, which can provide valuable insights into the fundamental laws of nature and advance our understanding of the universe.
What safety precautions are taken for particles in a linear accelerator?
Particles in a linear accelerator are handled with extreme caution and safety measures to prevent any harm to the operators and the surrounding environment. This includes shielding the accelerator and following strict protocols for handling and disposing of radioactive materials.
  • Classical Physics
