Particle on a sphere problem in quantum mechanics and its solution
7 replies · 2K views · last reply
Kashmir
To solve a particle on a sphere problem in quantum mechanics we get the below equation :##\left[\frac{1}{\sin \theta} \frac{d}{d \theta}\left(\sin \theta \frac{d}{d \theta}\right)-\frac{m^{2}}{\sin ^{2} \theta}\right] \Theta(\theta)=-A \Theta(\theta) ##
To solve this differential equation, we start with a change of independent variable ##z=\cos \theta##, where ##z## is the rectangular coordinate for the particle, assuming a unit sphere. We also introduce a new function
P(z)=\Theta(\theta) .
Using this substitution we've this equation
##\left(\left(1-z^{2}\right) \frac{d^{2}}{d z^{2}}-2 z \frac{d}{d z}+A-\frac{m^{2}}{\left(1-z^{2}\right)}\right) P(z)=0 ## whose solutions are the associated Legendre polynomials :
P_{\ell}^{-m}(z)=P_{\ell}^{m}(z)
To get back the angular solution I should use ##
P(z)=\Theta(\theta)## and also normalise it, giving me
##\Theta_{\ell}^{m}(\theta)= \frac{(2 \ell+1)}{2} \frac{(\ell-m) !}{(\ell+m) !} P_{\ell}^{m}(\cos \theta)##
But my book writes the solution with an additional ##(-1)^{m}## term as
##\Theta_{\ell}^{m}(\theta)= (-1)^{m}\frac{(2 \ell+1)}{2} \frac{(\ell-m) !}{(\ell+m) !} P_{\ell}^{m}(\cos \theta) ##
Why is that so?
dextercioby said:
What is your book? Do you know about parity transformations?
David McIntyre, Quantum mechanics.
I know little bit about parity operator.
dextercioby said:
Look up on the internet the "Condon-Shortley phase factor".
So the factor is there to simplify calculations.
Similarly defining for negative ##m##:
\Theta_{\ell}^{-m}(\theta)=(-1)^{m} \Theta_{\ell}^{m}(\theta), \quad m \geq 0 .
## is also to simplify calculations?
Why is that so?
What happens if you apply the raising operator ##L_+## to ##\Theta_{1}^{0}(\theta)##? Do you need a factor of ##(-1)^m## to satisfy ##L_+\Theta_{1}^{0} = \Theta_{1}^{1}##?
Hello sir.
I've not done the ladder operators for angular momentum. I'll do them and come back.
Thank you :)
