What Magnetic Field Strength Is Needed to Keep Protons at 7 TeV in the LHC?
The required magnetic field strength to maintain protons at 7 TeV in the Large Hadron Collider (LHC) is approximately 5.449 Teslas, based on calculations using the formula B = p/qr. The LHC has a circumference of 27 km, which translates to a radius of approximately 4.3 km. Initial calculations underestimated the magnetic field due to confusion over the energy units, specifically the distinction between energy in TeV and momentum in kg·m/s. The LHC operates at full power with a magnetic field of 8.3 Teslas, indicating that the calculated value is close but still below the operational requirement.
  • Understanding of Lorentz force and centripetal force equations
  • Familiarity with the cyclotron formula B = mv/qr
  • Knowledge of energy-momentum relations in particle physics
  • Basic proficiency in unit conversions within SI and particle physics contexts
  • Study the derivation and applications of the cyclotron formula in particle accelerators
  • Explore the energy-momentum relationship in relativistic physics
  • Learn about the operational parameters and design of the LHC
  • Investigate the implications of magnetic field strength on particle acceleration and collision outcomes
Physics students, particle physicists, engineers involved in accelerator design, and anyone interested in the operational mechanics of the Large Hadron Collider.
Wesley Strik
Estimate the magnetic field required to maintain protons at 7TeV in the LHC at CERN. The LHC has a circumference of 27 km. State any assumptions or approximations you make.
lorentz force, assuming magnetic field is always perpendicular to the direction of motion: F=qvB (q=charge of the proton) such that we can use the
Formula for centripetal force: F=1/r mv^2
---equating the two yields the cyclotron formula: B=mv/qr
relate momentum to mass velocity: p=mv then
B=p/qr is the equation we need ( I think)
I'm not completely sure as how to use the 7TeV energy given, this probably includes mass so I use the equation: E=p^2+M^2 assuming c=1 and all units are as such. I immediately notice that the mass of the proton is 938 MeV, this is a negligible amount compared to the 7TeV, so I suggest we just ignore the mass of the proton for this problem and treat all energy as kinetic energy such that: B=p/qr=(7* (5.36 x 10^-16 )kg m /s)/[(1.6022*10^-19 C)(27 * 10^3 m)]=0.867Teslas.
Am I making any mistakes here or do you guys get similar answers?
You're off by an order of magnitude according to this article:
https://en.wikipedia.org/wiki/Large_Hadron_Collider
At full power, the LHC is supposed to produce 8.3 T
In your calculation of B = p/qr, if r is supposed to be the radius of the collider, then 27 km is stated to be its circumference, not its radius.
ah yeah... reading.. I always suck at that. B=p/qr=(7* (5.36 x 10^-16 )kg m /s)/[(1.6022*10^-19 C)((27/(2 pi) *10^3) m)]=5.449 T does that look better? This is after assuming perfect conditions such as the LHC is perfectly round, the magnetic field is always perpendicular. It gets pretty close to the 8.3 Teslas, but still not very satisfactory tbh.
Just to enlighten me: if everything is in SI units, what is "7" ? and what happened to c=1 ?
[edit] Ah, I should have read 7 TeV/c , shouldn't I ? But did they give you a momentum of 7 TeV/c or did they give you an energy of 7 TeV/c2 ?
I just did that for the Pythagorean equation E^2=p^2+m^2, basically I say everything is energy, just as long as I remember all the units and conversion factors correctly. Well the 7 is because there is 7TeV(/c), not 1TeV(/c), the number behind it is the conversion factor to convert Mev(/c) to regular momentum units of kgm/s. ...SI in particle physics xD... with their microbarns and such
then perhaps the
confused me ?
[edit] found it. Sorry for barging in. Thank you for reminding me...:rolleyes:
should be E^2
I think this one is solved, others also got 5.4ish teslas
