Particles in a Magnetic Field Question
The discussion revolves around a problem involving the motion of doubly ionized particles in a magnetic field, specifically within the context of a mass spectrometer. The participants explore the relationship between potential difference, kinetic energy, and the forces acting on the particles as they move through the magnetic field.
  • Participants discuss deriving a formula for charge-to-mass ratio without directly using velocity. There are questions about the role of potential energy and how it relates to kinetic energy as the particles move through the potential difference.
The conversation has progressed through various interpretations of energy changes and relationships between variables. Some participants have provided guidance on the necessity of certain equations, while others have confirmed the understanding of energy transformations involved in the problem.
Participants are navigating through the implications of the equations provided and the physical principles governing charged particles in electric and magnetic fields. There is an emphasis on understanding the connections between energy, force, and motion without reaching a definitive conclusion on the problem's resolution.
pauladancer
A beam of doubly ionized particles (i.e., twice the elementary charge) is accelerated across a potential difference of 2000 V in a mass spectrometer. They are then passed perpendicularly through a magnetic field of 0.085 T resulting in a radius of curvature 12.5 cm. Calculate the mass of the unknown ion.
Fc= mv2/r
Fm= qvB
ΔV=ΔE/q
We are supposed to derive a formula for q/m without velocity. I think the solution probably involves the centripetal force being equal to something but I'm not sure what. Any help would be appreciated, thank you!
In your third relevant equation, where does the ΔE end up?
ΔE is the change in potential energy experienced by the particle. I could find that, but I'm not sure what I would do from there.
How is the change in energy expressed by the particle?
Sorry, I'm not quite sure what you mean! To be honest I'm not even sure if I need that equation.
Oh, you definitely need it :smile:
What happens to a charged particle when it "falls" through a potential difference? What about the particle changes?
Haha ok good! I guess it gains kinetic energy and loses potential energy, would that ΔE be equal to 1/2mv2?
Why, yes it would! :smile:
Perfect! Ok, so I can say that ΔE= 6.4x10-16 J which would also equal 1/2mv2. After that I'm still not sure what to do!
You now have an expression involving m and v. What's another relationship that involves m and v once the particle enters the magnetic field?
Fc= mv2/r ?
pauladancer said:
Fc= mv2/r ?
Try it.
gneill said:
Try it.
OH! So I can say Vq= 1/2mv2 and mv2/r= qvB... So I solved for v on both sides and got v=qBr/m and v=√2Vq/m and then combine those, solve for q/m and so q/m=2V/B2r2! I plugged in the numbers and got the right answer, 9.0x10-27 kg. Thank you so much for your help, glad I finally got it :)
Well done! Glad I could help.
9K
