Quantitative Analysis of Electron Motion in a Uniform Magnetic Field
The discussion centers on the motion of a beam of electrons traveling east at a speed of 6.10 x 106 m/s through a uniform magnetic field of 0.450 T directed vertically. The electrons experience a magnetic force that deflects their path into a circular motion. The correct calculation for the radius of this circular path is derived using the formula r = (mv) / (qB), resulting in a radius of approximately 7.7 x 10-5 m. The right-hand rule is applied to determine the direction of deflection, confirming that the electrons move counterclockwise when viewed from above.
  • Understanding of Lorentz force and its application to charged particles in magnetic fields
  • Familiarity with the right-hand rule for determining the direction of force on charged particles
  • Knowledge of fundamental constants such as the charge and mass of an electron
  • Basic principles of circular motion and centripetal force
  • Calculate the radius of electron motion in different magnetic field strengths
  • Explore the implications of varying speeds on the radius of circular motion in magnetic fields
  • Learn about the applications of electron motion in magnetic fields in devices like cyclotrons
  • Investigate the differences in motion for positively charged particles in magnetic fields
Physics students, educators, and researchers interested in electromagnetism, particularly those studying the behavior of charged particles in magnetic fields.
lloyd21
A beam of electrons travels east at speed, v = 6.10x 10^6 m/s . It passes through a magnetic field , B = 0.450T , directed from top to bottom. Describe exactly the path of the electrons motion?
The path of a charged particle moving in a plane perpendicular to a uniform magnetic field is a circle. The electron is moving east at v = 6.10x10^6m/s and the force on it deflects it downward. Because the force is always perpendicular to v, the magnitude of v does not change, and the electron moves at a constant speed. The electron moves clockwise in a circle.
I think this is right but I was told after to answer it , quantitatively? Eg. How large is the circle.
How can I show that? Thanks!
Check the deflection direction that you've claimed. Won't it change continuously of the path is circular? What's the initial direction of deflection?
For the calculation you'll want to look up the force experienced by a charge moving through a magnetic field. Then think circular motion...
The force would be 4.39x10^-13 N, and I should equate that with the centripetal force right? Except that gives me r= m (6.10x10^6 m/s) / (1.60x10^-19C) ( 0.450T) ...the initial direction of deflection would be downward?
Yes, and it's a circle in that plane. So what is the geometric relationship between the magnetic field lines and the circular path?
The magnetic field is vertical, right? It's a magnetic field, not an electrostatic field.
Are you saying it gives the wrong answer? What answer do you get? How do you know it's wrong?
I don't think its right because of my equation from what I showed above ^
And why is deflection of is downward wrong?
The magnetic field is oriented vertically. The electron's deflection must be in a direction perpendicular to both the field and the direction of motion of the electron.
So if the magnetic field is vertically from top to bottom, and the path of the electron is moving east, then the only way it can be perpendicular to both is to move out of the page or into the page?
Right. Or put another way, if the field is vertical then the deflection must be horizontal.
So using the right hand rule, it moves clockwise in a circle, which is into the page?
If the electron had a positive charge that would be true...
The right hand rule assumes that it is a positive charge that's moving in the magnetic field. Either switch to the left hand rule for the electron or reverse the direction that the right hand rule gives you.
Ive never used the left hand rule haha! So your saying flip what I just said, so it would be deflected towards me (out of the page) and would rotate counterclockwise
The sense of the rotation depends upon your point of view. If viewed from "above" it will turn clockwise. If viewed from "below" it will turn counterclockwise.
But the deflection is on the horizontal plane regardless...how do I get the size of the circle, I equated the force experienced by a charge moving through a magnetic field which I got 4.39 x10^-13 N. Then think circular motion should be r = (mv/qb) , but I cannot find m? I get r = m (6.10x 10^6m/s) / (1.50x10^-19 C)( 0.450 T)
You should be able to look up the charge and mass of an electron. They are fundamental constants.
Centripetal Force = 7.8 x10^5 m
Magnetic Force = 4.39x10^-13 N
if they have to equal each other, would I use F= m (v^2) / r ?
I used r= (mv) / (qB) from before and found 7.8 x10^5 m...im not sure how to equate them when I found both answers?
Nevermind, I used Bqv = mv^2 / r
so r = (9.1 x 10^-31kg)(6.10x10^6m/s) ^2 / (4.39x10^-13N)
resulting in = 7.7 x 10^-5 m
The equation r= (mv) / (qB) is derived from F=qBv and F=mv2/r. There's nothing to be gained by going around that loop again.
You know q, B and v, and you can look up m. So calculate r.
I did that above ^^^, does that look correct? very small circle.
It's a very strong field.
Thanks for the help!
  • · Replies 31 ·
  • · Replies 25 ·
