PDF and CDF Integration Simplification
  • Level: Graduate
  • Thread starter Thread starter EngWiPy
    Cdf Manipulation Pdf
12 replies · 4K views · last reply
EngWiPy
Hello,
I have this equation:
[tex]\int_{-\infty}^{\gamma}f_X(x)\,dx+\int_{\gamma}^{\infty}F_Y(x-\gamma)\,f_X(x)\,dx[/tex]
where [tex]f_X(x)[/tex] and [tex]F_Y(y)[/tex] are the PDF and CDF of the randome variables X and Y, respectively.
Now the question is: can I write the above equation in the form:
[tex]1-\int_{0}^{\infty}(...)[/tex]
Regards
Try starting with
[tex] \int_{-\infty}^\gamma f_X(x) \, dx = \int_{-\infy}^\infty f_X (x) \, dx - \infty_\gamma^\infty f_X(x) \, dx = 1 - \infty_\gamma^\infty f_X(x) \, dx [/tex]
What statdad meant to say was: Try starting with
[tex]\int_{-\infty}^{\gamma} f_X(x)\,dx =<br /> \int_{-\infty}^{\infty} f_X(x)\,dx \;- \,\int_{\gamma}^{\infty}f_X(x\,)dx =<br /> 1 \,- \int_{\gamma}^{\infty}f_X(x)dx[/tex]
Yes indeed, but statdad, in his advanced age, was interrupted by some annoying folks at the door and neglected to fix his post. Thanks.
Yes, but I want the whole right side be one minus single integral. Is this still doable in some how?
Yes: you can write
[tex] 1 - \int_\gamma^\infty \left(f_X(x) - F_Y(x-\gamma)f_X(x)\right) \, dx[/tex]
You should be able to take this and write it as
[tex] 1 - \int_0^\infty ( \cdots ) \, dx[/tex]
just play around with the integrand.
statdad said:
Yes: you can write
Thank you, but this form is not the one in my mind. I need, if possible, in some how, to eliminate the first term, so that the equation looks like:
[tex]1-\int_0^{\infty}F_Y(a)\,f_X(a+\gamma)\,da[/tex]​
Regards
Look at the integrand in
[tex] \int_\gamma^\infty \left(f_X(x) - F_Y(x-\gamma)f_X(x)\right) \, dx[/tex]
You should see a very simple way to factor it and then rewrite it in a form more suitable to your desires for this problem.
Try it - do some work - then post again.
I can't see anything that I can do. :shy:
statdad said:
Look a little harder. I won't give away the answer.
Just give me a hint, I am not strong in probability.
Work with the integrand.
Are you sure that, we can write [tex]\int_\gamma^\infty \left(f_X(x) - F_Y(x-\gamma)f_X(x)\right) \, dx[/tex] as [tex]\int_0^{\infty}F_Y(a)\,f_X(a+\gamma)\,da[/tex]?
