Why Does a Pendulum's Motion Change Direction Over Time?
  • Context: High School
  • Thread starter Thread starter Josh Wilson
    Direction Pendulum
The discussion centers on the changing motion of a pendulum, specifically a lamp, which initially swings linearly but gradually transitions to a more complex elliptical motion. This phenomenon is attributed to the suspension system's characteristics, including the elasticity of the cord and the interaction of different oscillation modes. The terms 'major swing' and 'minor swing' are introduced to describe the two primary directions of motion, which have differing periods, leading to the elliptical trajectory. The complexity of maintaining a consistent swing direction is highlighted as a challenge in constructing a Foucault pendulum.
  • Understanding of pendulum mechanics
  • Familiarity with oscillation modes
  • Knowledge of suspension systems and their properties
  • Basic principles of Foucault pendulum dynamics
  • Research the principles of elliptical motion in pendulums
  • Study the effects of suspension system elasticity on pendulum behavior
  • Learn about Foucault pendulum construction techniques
  • Explore higher order oscillation modes in mechanical systems
Physics enthusiasts, engineering students, and anyone interested in the dynamics of pendulum motion and its complexities.
Josh Wilson
Occasionally while eating at restaurants, I will swing the lamp hanging above the table and observe its motion. One feature has puzzled me for some time: at first the light swings back and forth linearly in the plane of motion corresponding to the initial release point. However, after some time the pendulum (light) changes its motion so as to swing sometimes in a circular fashion, and sometimes in a linear fashion whose direction is different than the initial direction. The direction and type of motion seem to be constantly changing.
Is this a feature of pendulums in general, or is there some complexity due to the fact that the light is not a simple point mass?
Welcome to PF, Josh.
I'm the least educated person here, so I can give you only my initial thought as opposed to something solid. My first thought is that the motion probably has more to do with the suspension system (chain, electrical cord, rods, etc.) than with the lamp itself. That's probably wrong, but the first thing that comes to mind.
You may be right. I suspect there is some coupling to higher order oscillation modes which causes the pendulum direction to slowly change over time - though these modes must be too small to actually see. Initially, I thought it might be some kind of Foucault pendulum effect, but then the oscillation would only change direction once per day...
The cord of the lamp will not be equally elastic in all directions. Or maybe for some direction of swing the effective cord length is longest in one particular direction of swing, and shortest in the perpendicular direction. And period of swing depends on cord length.
Probably those two directions already have names, but I can't remember. I'll just make up new names. 'Major swing' and 'minor swing' for the two directions described above.
When you start a lamp swinging you can think of its initial swing as a composition of partly major swing and partly minor swing. As described, the major swing and the minor swing don't have the same period. As a consequence, what is initially a linear swing opens up, changing into motion along an ellipse.
This effect is one of the reasons that building a Foucault pendulum setup is very hard. Additional measures are necessary to keep the plane of swing from opening up.
  • · Replies 37 ·
  • · Replies 17 ·
  • · Replies 117 ·
