What Is the Correct Equation of Motion for a Pendulum at Any Amplitude?
The correct equation of motion for a pendulum at any amplitude is derived from the differential equation \(\frac{d\phi^2}{dt^2}=-\frac{g}{l} \sin(\phi)\). For small angles, the approximation leads to the equations \(x = \sin(\theta \sin(\sqrt{\frac{g}{l}t})) \cdot l\) and \(y = \cos(\theta \sin(\sqrt{\frac{g}{l}t})) \cdot l - l\). However, for larger amplitudes, there is no analytic solution available. The discussion emphasizes the importance of specifying the amplitude when determining the equation of motion.
  • Understanding of pendulum dynamics
  • Familiarity with differential equations
  • Knowledge of trigonometric functions
  • Basic physics concepts such as force and acceleration
  • Research the derivation of the pendulum's motion using numerical methods
  • Explore the implications of the small angle approximation in pendulum motion
  • Study the effects of damping on pendulum motion
  • Learn about the mathematical modeling of nonlinear oscillators
Physics students, educators, and engineers interested in classical mechanics, particularly those studying oscillatory motion and pendulum dynamics.
olgerm
what is equation of motion for pendulum?pendulum is made of pointmass, which mass is m, is fixed to thread ,which length is l? Oscillation aplitude is θ.Other side of thread is fixed in (0;0;0)point. at time t=0
t=0;y=0<br /> ;z=0<br /> ;φ=θ
\frac{dφ^2}{dt^2}=-\frac{g}{l}*Sin(φ)
x(t)=?
y(t)=0
z(t)=0
t(t)=t
Small angle approximation!
t=0;<br /> ;z=0<br /> ;φ=θ
x(t)=?
y(t)=?
z(t)=0
t(t)=t
What is small angel approximation ? The relevant equation I wrote?
Google it.
Draw a picture! If the line of the pendulum is at angle \theta to the vertical the force acting on the pendulum bob is straight down but the pendulum string prevents the bob from moving straight down. Divide the force into components perpendicular to and parallel to the circular arc the pendulum bob makes. The use "force= mass times acceleration".
φ=θ*sin(\sqrt{\frac{g}{l}*t})
\begin{cases}<br /> x=sin(φ)*l\\<br /> y=l*(cos(φ)*-1)\\<br /> \end{cases}
So correct equation of motion is
\begin{cases}<br /> x=sin(θ*sin(\sqrt{\frac{g}{l}*t}))*l\\<br /> y=cos(θ*sin(\sqrt{\frac{g}{l}*t}))*l-l\\<br /> \end{cases}
For small amplitude, that's roughly right, but doesn't satisfy the given initial conditions.
However, the OP does not specify small angles, so it's not clear whether this is what is wanted. Maybe they just want the differential equation, but using x and y instead of ##\phi##.
What is the correct equation for any amplitude?
I mean motion of equation of pendulum "head".
x(t)=??
y(t)=??
x(t)=??
y(t)=??
There is no analytic solution.
  • · Replies 32 ·
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 27 ·
