Pendulum Harmonic Motion Help Needed Asap ( work is shown)
The problem involves a bungee jumper oscillating after a jump, requiring calculations related to harmonic motion and the properties of the bungee cord, specifically the spring stiffness constant and the unstretched length of the cord.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss calculating the spring stiffness constant using the period of oscillation and mass. There is an exploration of different formulas to find the unstretched length of the bungee cord, with some questioning the appropriateness of the formulas used.
Some participants have confirmed the correctness of the spring stiffness constant calculation. There is ongoing clarification regarding the relationship between force, distance, and the spring constant, with attempts to derive the unstretched length from the information given in the problem.
Participants are working under the constraints of the problem statement, specifically the final resting position of the jumper and the mass involved. There is confusion regarding the definitions of variables in the context of Hooke's law.
chazgurl4life
A bungee jumper with mass 66.0 kg jumps from a high bridge. After reaching his lowest point, he oscillates up and down, hitting a low point eight more times in 35.5 s. He finally comes to rest 28.0 m below the level of the bridge.
Calculate the spring stiffness constant of the bungee cord.
N/m
For this part i figured i could solve for period (T) which would be the 35.5 sec /8 whihc is 4.4375 s
and then i used T=2pi* (m/k)^1/2
and with that i thought i could solve for K
that comes out to be ...k=(4pi^2*mass) / T^2
so k=132.3 N/m
Calculate the unstretched length of the bungee cord
I could either use T= 2*PI*(L/G)^1/2
L=(4.4375 s^2 * 9.8)/4*pi^2-4.88 m ...but that's wrong
OR I COULD USE ---f= 1/2*pi *(g/l)^1/2 ...
L=(2.46*g)/f^2=477.69 m
and just solve for L ...rite?
but when i plug everything in i keep getting it wrong
No no no no.
The first part (finding k) was correct. Exactly right. But then you start using other formula to find L simply because they have an L in them.
Here's a hint. You have just found the "k," and you are given a distance and a mass (from which you can find a force). What kind of relationship is there for stretchy things that relates force, distance and a "k" ?
ok i know that Force = - kx
could x=length of the bungee cord...
and which would lead me to believe that M*g=force also equals -Kx
so...should i be using 66kg (9.8)=-132.3(x) and solve for x?
Yes, you should solve for x, but realize that x is not the unstretched length of the cord.
The x in Hooke's law (F = -kx) refers to the amount by which the spring (or cord) is stretched from its unstretched position.
so how do i figure out the unstretched length...now I am confused
Make full use of the information provided in the problem statement, namely:
"He finally comes to rest 28.0 m below the level of the bridge."​
ok i think i got it...so ...66*9.8=-(132.3)x
X in this case is -4.8 ms.. so if i add that to the 28 meters the unstretched cord should be in length equal to 23.1 meters ...that should be rite
That's what I get.
  • · Replies 32 ·
