Pendulum Tension Force -- How to calculate the full vector?
39 replies · 7K views · last reply
babaliaris
Diagram of a pendulum released from rest at the top of a quarter circle of radius r = l, with the bottom point labelled PE = mgh and h = l. At the bottom, arrows show T pointing up, mg pointing down, and the velocity v. Right side equations: sum F_c = m a_c; T - mg = m v^2/r; T - mg = m(sqrt(2gl))^2/l; T - mg = 2mg; T = 3mg (circled).
Hello! I'm trying to understand how this pendulum works. I found this video that explains how to calculate the T force from the rope.
He uses the preservation of kinetic and potential energy in order to find the magnitude of the velocity and then using Newton's second law, he calculates the T force.
My question is, if I understand correctly he only calculated the T in the direction of the y axis, not the x. So this is not the full answer.
In other words ##T_{y_{0}}=3mg##.
I want to know the full vector ##T = T_{x_{0}} + T_{y_{0}}## or ##T(x,y)##
Can I follow the same idea and use ΣF=ma on the x-axis? The gravity force is zero there, but what should I use for a? Maybe the tangent acceleration ##a_{T} = \frac{dV}{dt}## (where V is the magnitude of the velocity)?
Newton's second law says ##\mathbf{F}_{\text{net}}=m\mathbf{a}##. There are two forces acting on the pendulum, gravity and tension. When the pendulum passes through the vertical position, they do not have a horizontal component.
Question 1: What is the horizontal component of the net force?
Question 2: According to Newton's second law, what should the horizontal component of the acceleration be?
You are right, when it passes through the vertical position the horizontal component of T is zero. At that point the horizontal component of the net force should also be zero because gravity doesn't have one as well, in fact, gravity is always zero on the x-axis along the whole motion. So ##T_{x_{0}} + W_{x_{0}} = 0##
##Σf = ma <= > -mgy_{0} + T1x_{0} + T2y_{0} = m(a1x_{0} + a2y_{0})## so ##a1x_{0} = \frac{T1}{m}x_{0}##
And if I'm not mistaken, |T| = 3mg since T is always constant in magnitude, only its direction changes.
babaliaris said:
You are right, when it passes through the vertical position the horizontal component of T is zero. At that point the horizontal component of the net force should also be zero because gravity doesn't have one as well, in fact, gravity is always zero on the x-axis along the whole motion. So ##T_{x_{0}} + W_{x_{0}} = 0####Σf = ma <= > -mgy_{0} + T1x_{0} + T2y_{0} = m(a1x_{0} + a2y_{0})## so ##a1x_{0} = \frac{T1}{m}x_{0}##
I agree that
##F_{\text{net,x}}=T_{x_0}+W_{x_0}=0.##
Newton says
##F_{\text{net,x}}=ma_x.##
Can you put the two equations together to find the horizontal acceleration?
It should be 0 right? ##a_{x} = \frac{F_{net,x}}{m} = 0## We are talking about when the m passes through the vertical position right?
Now, what happens at a random point in time? Can you give me an idea on how to approach this problem in order to find out T as a vector? I believe the magnitude of T does not change, only it's direction, that's what my senses are telling me. If this is true, then from the calculations of my original post, |T| should be equal to |T| = 3mg. So I just need to find a way to describe that vector as a function of θ(t) which will change T's direction.
Well, you senses are deceiving you here. Draw a free body diagram of the mass when it is at angle ##\theta## with respect to the vertical moving with speed ##v##. Calculate the tension as a function of angle and ##v##.
I'll try it and report back when I'm ready!
Handwritten derivation on lined paper of a pendulum's position r(t) = L[sin θ(t) x̂ + cos θ(t) ŷ], with the velocity v(t) = Lω(t) and a labelled diagram of the rope at angle θ.
Handwritten derivation on lined paper: tangential acceleration a_T = L·dω/dt, normal acceleration a_N = L·ω² with boxed results, then Newton's law sum F = m·a in x and y components giving a1 = T1/m and a2 = -g + T2/m.
This is as far as I reached. I don't know what to do now since I'm not sure what a1, and a2 are equal to.
PS: I also attached a Pendulum Analysis.pdf file in case you can't read the pictures.
But these equations don't stand in this problem. The magnitude of V can't be Lω(t) since this would be true if it was in a circular motion, but in this problem, the pendulum oscillates in an arc motion.
Diagram 2 is where you start. You should not substitute ##x(t)## in anything. This is how to proceed.
  1. Consider perpendicular axes along the rope, radial or r-direction, and perpendicular to it, tangential or t-direction.
  2. Write the components of the two forces in the r-direction.
  3. Write Newton's second law in the r-direction. That should give you the tension in the rope when the pendulum is at angle ##\theta## and the pendulum mass has speed ##v.##
Please execute step 2 in post #11 and type your answers.
In the r-direction
Tr =
Wr =
ar =
Also note that there is only one angle θ. All other pertinent angles are either θ or 90°- θ. There is no need for subscripts because cos(90°- θ) = sinθ and sin(90°- θ) =cosθ.
I can not understand what you mean by the r direction. Maybe I'm missing some mathematical knowledge?
The r-direction is in the direction of the rope. See the diagram below. Vectors are red, axes are black.
Free-body diagram of a pendulum bob with red force vectors: tension T along the rope toward the upper right, weight W straight down. Black axes r (along the rope) and t (perpendicular), with angle theta from a dashed vertical line.
All the mathematical knowledge you need is how to resolve a vector into components along two perpendicular directions.
But this is what I did, didn't I?
Handwritten free-body diagram of a pendulum mass m with weight W split into components Wx and Wy, angles θ(t), δ2, δ3, δ4 marked, and handwritten angle derivations and equations numbered 1 to 6 below.
Then I calculated Wy and Wx where Wy is in the opposite r-direction as you describe.
T is always parallel with the r-direction which means it has only one component, the other one is zero.
OK, if that's what you did, then the next step is to use what you did and write expressions for the component of the net force in the r-direction.
##F_{\text{net,r}} =~## _______________
and the acceleration in the r-direction
##a_{\text{r}} =~## _______________
Fill in the blanks. If you insist on posting hand-drawn diagrams, make sure the above are clearly shown as indicated above. Also, your expressions on the right-hand side must have no symbols other than ##\theta## and its trig functions, the mass ##m##, the length ##L##, the acceleration of gravity ##g##, the speed ##v## and tension ##T##.
Please do not use ##\theta_1##, ##\theta_2## and ##\theta_3##. The trig functions of all these angles can be reduced to functions of angle ##\theta## as defined in post #15. The goal is to find the dependence of the tension on this angle ##\theta##.
Yes I know how to reduce it to just Θ and how to use the odd and even properties of sine and cosine to get rid off the 90 degrees as well.
The problem now is acceleration. This is the only thing (for now) that I don't know what it's equal to. I don't even know how to draw it on the diagram. Should I just draw it in a random angle, and just analyse it's components using sine and cosine as functions of Θ?
Yes, exactly!
Then do it and post the results.
The acceleration would not be a problem if you did what I asked you to do, namely,
  1. Item 2 in post ##1 or
  2. fill in the blanks in post #13 or
  3. fill in the blanks in post #17
In general you would have to write two equations for Newton's second law, one in the r-direction and one in the t-direction (see post #15). For what you want to do here, the r-direction is of value and the t-direction is not. I want to help you but if you choose not to take my advice, I will have nothing more to say because I have said it three times already. If you don't understand or don't know how to follow my advice, just say so and I will help you along.
babaliaris said:
The problem now is acceleration. This is the only thing (for now) that I don't know what it's equal to. I don't even know how to draw it on the diagram...
Diagram of a simple pendulum: a ball on a black string hangs from a hatched ceiling, with a dashed vertical line and angle theta between the string and vertical; a red vector labelled a points down and to the left from the ball.
@babaliaris
Regarding previous animation:
Please, note that at each instant of the oscillation, the shown acceleration (red vector) can be visualized as the vectorial addition of the centripetal and tangential accelerations.
As you can see, the value of the centripetal acceleration (tension in your cord) depends on the tangential velocity, therefore, it is zero when the pendulum momentarily stops, and maximum at the lowest point.
Lnewqban said:
@babaliaris
This is a nice animation. The animator also shows the conventional counterclockwise direction of increasing angle ##\theta.## Maybe I'm greedy but it would be nice if there were a way to show the angular velocity and angular acceleration vectors as well.
Handwritten notes titled Calculating Angles with a small force diagram of a mass m on an inclined axis, followed by derivations of angle relations and component expressions for w_x, w_y, a_x and a_y in terms of cos and sin.
Handwritten derivation titled Newton's Law on lined paper, solving for pendulum tension: sum of Fx gives g sin(θ) = |a| cos(θ), so |a| = g tan(θ), and the final boxed result is |T| = m g [tan(θ) sin(θ) − cos(θ)].
I think I figured it out (If I don't have any mistakes).
But I think I have. I calculated T and ##tan(θ)sin(θ)-cos(θ)## gives a negative number.
But T should always point towards the positive y-axis. Something feels wrong...
Can you tell me my mistake? Thank you!
OK, you chose "y" instead of "r" for the direction along the rope. That's fine. Let's look at ##T_y##. The first occurrence of the tension in your most recent work is here
Handwritten vector equation: W_y + T + T = m·a_y, where the second T is crossed out and the vector arrows sit above each symbol.
First of all, the variables in this equation are scalar quantities, not vectors, so you should be putting the arrows over them. This equation is correct and is the one I wanted you to start from. So you have
##W_y+T=ma_y##
Now farther up in work you have equation (4) ##W_y=mg\cos\theta##. That is incorrect. Do you see why? Hint: The trig function is correct. Also, you will need to find an expression for ##a_y## in terms of the speed ##v##. Hint: the mass is describing a circle as it moves.
Also, you cannot replace ##|\vec a|## in the top equation with ##g## and get the bottom equation. That is absolutely wrong because if the acceleration of the mass is ##g## that means it is in free fall which it isn't.
Handwritten derivation of pendulum tension magnitude: first line |T| = m|a| sin(θ) - m·g·cos(θ); second line |T| = m·g·tan(θ) sin(θ) - m·g·cos(θ).
Is this correct about the magnitude of the acceleration?
Handwritten derivation on lined paper: sum of Fx = m ax gives mg sin(θ) = m|a| cos(θ), then |a| = g sin(θ)/cos(θ), boxed as |a| = g tan(θ).
As you said the magnitude can not be just g. But also tan(θ) can give negative answers, so how is this a correct magnitude? Maybe, because my coordinate system moves with the ball the system flips when the ball is on the right-hand side of the diagram? So that the positive x-axis will point to the left? If you see θ as measured from the "world" coordinate system (the one that has (0,0) in the wall where the rope is attached) when θ is between 180 and 270 degrees (this is what I draw in my diagram) then tan(θ) is positive (because sin and cos are negative there, both of them), this explains why the magnitude is positive there. But when θ is between 270-360 degrees, tan(θ) < 0 so it seems like ##a_{x}## flips horizontally.
Well if my math for the acceleration is correct, then I can say ##a = gtan(θ)cos(θ)x_{0} + gtan(θ)sin(θ)y_{0}## then integrate to find the velocity. Then I can take the magnitude of the velocity and integrate that to find the path of the motion ##\frac{ds}{dt}=|v|##
You are off the track. Let's try something simple. Consider a mass going around a circle of radius ##R## at constant speed ##V##. Is it accelerating? If "yes", what is its acceleration? If "no", why not?
Yes it is accelerating but the acceleration chages only the direction of the velocity keeping it's magnitude constant. It's acceleration I believe is ##R \cdot \frac{dω(t)}{dt}##
Edit:
By the way, I noticed something in my way of thinking when you said that these are scalar quantities (in the ##ΣF_{y}=ma_{y}##). I thought the cos and sine were giving the direction of these vectors, but the truth is that these components were described with a 0 < θ < 90, since if you see the angle between the components, it's 90 degrees. So for example ##W_{x} = mgsin(θ) ## or ##a_{x} = |a| cos(θ)## the trig functions give 0<= cos(θ) <= 1, 0<= sin(θ) <= 1 (only positive numbers). So these trig functions control the length of the magnitude.
In other words, I had to add signs as well when writing the ΣF equations which I didn't do.
If there is acceleration in the direction of the velocity, the mass will not move at constant speed which is the kind of motion we are considering. The component of the acceleration ##R\frac{d\omea}{dt}## is the tangential acceleration and changes the speed. Here the mass is assumed to go around at constant speed. So try again, what is its acceleration?
You have defined x and y axes. In your drawing (shown below) you have vectors ##\vec T## and ##\vec W##. Which of these two (if any) has a negative component in either direction? What is this component?
Handwritten free-body diagram of a mass m on an incline-like axis with labeled vectors T, W, a_x, a_y, and angles θ, with rotated x and y axes and a pulley at upper right.
