Pendulum Tension Force -- How to calculate the full vector?
39 replies · 6K views
babaliaris said:
In other words, I had to add signs as well when writing the ΣF equations which I didn't do.
OK, then do it and write the correct equation for Newton's second law in the y (or r) direction. Be sure to have the correct expression for the acceleration in terms of the speed ##V##.
I think I solved it. By the way, I wanted to find out θ(t).
I don't think you solved it correctly. The tension depends on the speed ##V##. Your expression for it does not. If you want to find θ(t), you have to solve the differential equation $$\frac{d^2\theta}{dt^2}+\frac{g}{L}\sin\theta =0.$$ You can only solve it approximately, e.g. use the small-angle approximation ##\sin\theta \approx \theta## which of course is invalid here because the pendulum starts at the horizontal position. However, you can find the angular speed as a function of angle, ##\omega(\theta).##
Can anyone point out my mistake? Maybe the mistake is the way I describe acceleration, it's the only thing I'm not completely sure if it is correct.
Maybe the way that I said ##a_{T} = |a|cos(θ)## ##a_{Ν} = |a|sin(θ)## and then calculated ##|a|## from ##ΣF_{T}=ma_{T}## it's not correct.
And instead, maybe I should have written the ##ΣF_{N} = ma_{N} = m \frac{|V|^{2}}{L}## and use this one to find the tension.
But I would like to know what I did wrong.
I don't see any mistakes in my math, so it must be something in my "Physics way of thinking".
##T = m[\frac{|V(t)|^2}{L} + gcos(θ(t))]##
And If I'm correct, this is not a conservative force since it depends on the velocity which depends on time, so, if I was using the principle of conservation of mechanical energy (potential energy in highest point + kinetic energy in highest point = potential energy at the lowest point + kinetic energy at the lowest point) it would be wrong.
It doesn't matter if the tension is conservative or not. It is always perpendicular to the path and ##dW=\mathbf{T}\cdot d\mathbf{s}=0##. This means that the tension does zero work on the mass. It changes the direction of the velocity ##\mathbf{V}## but not the speed ##V##. Use energy conservation to find an expression for ##mV^2## in terms of ##\theta## and put in the equation.
It's easier with Lagrange I, i.e., you don't introduce the angle as a generalized parameter but work with (plane) Cartesian coordinates and imposing the constraint with a Lagrange parameter. The corresponding Lagrangian reads (setting ##\vec{x}=(x,y)##)
$$L=\frac{m}{2} \dot{\vec{x}}^2 -mg y +\frac{\lambda}{2} (\vec{x}^2-L^2).$$
The Euler-Lagrange equations read
$$m \ddot{x} = \lambda x, \quad m \ddot{y}=-mg + \lambda y.$$
From this it follows
$$\vec{T}=m \ddot{x}+m g \vec{e}_y = \lambda \vec{x}.$$
To get ##\lambda## note that
$$m x \ddot{x} + m (\ddot{y}+g) y = \lambda(x^2+y^2)=\lambda L^2 \; \Rightarrow \; \lambda = \frac{m(\vec{x} \cdot \ddot{\vec{x}}+g y)}{L^2}.$$
Now you introduce ##\theta## via ##\vec{x}=L(\sin \theta,-\cos \theta)##. Plugging this into the formula for ##\lambda## you find
$$\lambda=-\frac{m}{L} (L \dot{\theta}^2 + g \cos \theta).$$
Thus
$$\vec{T}=-m(L \dot{\theta}^2 + g \cos \theta) \begin{pmatrix}\sin \theta \\ -\cos \theta \end{pmatrix}$$
and
$$|\vec{T}|=m(L \dot{\theta}^2 + g \cos \theta).$$
I understand what you are saying, thanks for this note.
I'm not sure about the potential energy when the pendulum is at its maximum angle, because I don't know what the height is there. I saw on the internet people taking the height = L when the angle of the pendulum is 90 degrees but is this correct? I don't know if the pendulum can reach that high. Maybe it does not matter in terms of energy, since they could reach there if I calmy v(0) = 0 leaving it to fall while holding it at 90 degrees.
Thus
and
I don't understand this math :P
Gravitational potential energy near the surface of the Earth is ##U=mgy## where ##y## is the vertical distance from an origin of your choice to the point where you want to find the potential energy. If you choose the lowest point of the motion as the origin, then what do you think is the vertical distance of the mass from the lowest point? Look at the picture that you yourself posted.
If you have not seen Lagrangians, you will not be able to understand the math in post #38.
