Percentage energy loss (mechanical energy) problem
The problem involves calculating the percentage energy loss of an object sliding down a low-friction incline, with specific measurements of mass, height, and speed at different points during its motion.
  • Participants discuss the original poster's attempt to apply energy conservation principles and question the calculations involved. There are suggestions to clarify the conversion to percentage and to isolate the work done by other forces.
The discussion is ongoing, with participants providing feedback on the original approach and emphasizing the need for detailed calculations. There is no explicit consensus, but several participants are guiding the original poster towards refining their method.
Participants note potential issues with the calculations and the interpretation of energy loss, as well as the importance of showing all steps in the reasoning process.
poopandpee
Problem: An object with mass 2.0 kg slides down a low-friction incline and its speed measured at the bottom is 2.7 m/s. The object starts sliding at a height of 0.50 m over the tabletop and its speed is measured 0.10 m over the tabletop. How big is the percentage energy loss?
My attempt: I've tried using this formula: mgh(0) + W(other forces) = 0.5mv2, where m=2.0 kg, h=0.4 m, and v=2.7 Then I found W(other forces) and divided it by mgh(0). However, that did not give a right answer. Any suggestions?
The sign of the energy loss is a bit questionable but overall the approach is good. Maybe some mistake in the calculations? You didn't show them.
Did you remember to multiply by 100 to convert to %?
You shouldn't divide by the other work, if your equation above is correct you should subtract mgh(0) to get W alone
That appears to be what @poopandpee did before dividing:
As others have posted, the method sounds correct, but we need to see the details.
