How Do You Calculate the Period of Small Oscillations in Physics?
The discussion focuses on calculating the period of small oscillations for a particle in a potential defined by the function V(x). The key formula used is the period of oscillation, given by 2π√(m/V''(x)), where the second derivative V''(x) is evaluated at the equilibrium position x = -3^{1/4}a. The final expression for the period derived is 2π√(4a^3/(3^{5/4}λ)). Participants also explore the implications of energy conservation in relation to the potential energy at specific points, confirming that if the initial velocity v_0^2 > λ/a, the particle will reach x = a.
  • Understanding of classical mechanics, specifically oscillatory motion.
  • Familiarity with potential energy functions and their derivatives.
  • Knowledge of energy conservation principles in physics.
  • Ability to manipulate algebraic expressions involving derivatives.
  • Study the derivation of the second derivative of potential energy functions, specifically V''(x).
  • Learn about the stability of equilibrium points in oscillatory systems.
  • Explore energy conservation in conservative force fields.
  • Investigate the behavior of particles in potential wells and the implications for motion.
Students and educators in physics, particularly those studying mechanics and oscillatory motion, as well as anyone interested in the mathematical modeling of physical systems.
synkk
Q: http://gyazo.com/1ee7eee0134c25a23b4ad7a6972e1e46
part a)
I have drawn the graph and calculated ## V'(x) = \dfrac{3\lambda x^2 (x^4 + a^4) - \lambda x^3(4x^3)}{(x^4+a^4)^2} = 0 ## and found using the graph that the value of x when the particle is in a stable equilibrium is ## x= -3^{\frac{1}{4}}a ## but I'm not sure how to find the small period of oscillations, I know the formula is ## \dfrac{2\pi}{w} = 2\pi \sqrt{\dfrac{m}{V''(X)}} ## but working out V''(x) is fine, but subbing in the value of x is a lot of algebra to do without a calculator and I have a feeling there is an easier way which I am missing
I think your approach is good. I don't see an easier way. If you've already found an expression for V''(x), then it's not too bad to substitute the equilibrium value for x and simplify.
Note that the first derivative V'(x) has the form f(x)/g(x). At the equilibrium value xo, you have f(xo) = 0.
Then V''(xo) = f##\;##'(xo)/g(xo) - f(xo)g'(xo))/g(xo)^2.
The second term on the right is zero because f(xo) = 0.
Thanks, that helped make it easier,
After plugging it all in I ended up with the period of small oscillations to be ## 2\pi \sqrt{\dfrac{4a^3}{3^{\frac{5}{4}}\lambda}}## which seems strange, doesn't look "nice" and usually in my homework problems solutions usually look tidy.
Moving on to the next part of the question, I need to show that if x = a it implies that ## v_0 > \frac{\lambda}{a} ## I done this using the energy equation ## E = \frac{1}{2}v_0^2 + V(X) ## and subbing in x = a I get ## v_0^2 + \frac{\lambda}{a} = 2E## as E > 0 and 2E>0 then ## v_0^2 > \frac{\lambda}{a} ## I'm having troubles proving it the other way round however,
i.e. if ## v_0^2 > \frac{\lambda}{a} ## then x = a is it as simple to say that as ## E > \frac{\lambda}{a} ## and ##E = \frac{1}{2}v_0^2 + V(x) ## then V(x) must equal ## \frac{\lambda}{2a} ## in order for E to be ## > \frac{\lambda}{a} ## i.e. x = a ----------- NVM this is incorrect, using ## E > \frac{\lambda}{a} ## is a result I got from assuming x = a :|
Also, generally I'm confused about the question, it states that if the particle in the positive x direction then show it will go through a, but if it goes through a then wouldn't the particle keep on moving to + infinity? If so, then how could it possible go back to -a
If ##v_o^2 > \lambda/a## then ##E > \lambda/(2a)##. The only way the particle will not make it to ##x = a## is if the kinetic energy goes to zero at some value of ##x##, say ##x_{\rm max}##, such that ##x_{\rm max} < a##. Think about what that means for the potential energy at ##x_{\rm max}## and use the sketch of your graph to argue that there is no such ##x_{\rm max}## that is less than ##a##.
For the last question, note that it is possible for the particle to make it past ##x = a## without moving on to + infinity. Again, your graph might be helpful.
ok, thanks for the tips, the reason I had troubles with believing it went back down is because I thought 3^(1/4)a was < a, lol.
Anyway, here is my attempt for proving the "only if":
if ## v_0^2 > \frac{\lambda}{a} ## then as ## V(x) > 0 ## for all positive x then ## E > \frac{\lambda}{2a} ##
assume ## x \not= a ## then ##\exists x_{m} ## s.t. ## x_m < a ##
this implies that ## V(x_m) = E ## as the particle stops moving - but ## as V(x_m) < V(a) = \frac{\lambda}{2a} ## this implies that ## E < \frac{\lambda}{2a} ## which is a contradiction hence x must equal a
is this correct?
for the last part:
if the particle goes to x = -a then the energy must be below the maximum point of the graph, i.e. ## E < 3^{1/4}a \Rightarrow \frac{1}{2} v_0^2 + V(-a) < 3^{1/4}a \Rightarrow v_0^2 < 2\times3^{1/4}a - \frac{\lambda}{a} ##
and ## v_0^2 > \frac{-\lambda}{a} ## so ## \frac{-\lambda}{a} < v_0^2 < 2\times3^{1/4}a - \frac{\lambda}{a} ##
There is no need for the phrase "V(x) > 0 for all positive x". At x = 0 you can show that ##E > \frac{\lambda}{2a}## and by conservation of energy, ##E > \frac{\lambda}{2a}## for all values of x that the particle makes it to.
is this correct?
Yes, essentially. I had suggested that you could approach the problem by assuming that the particle does not make it past ##x = a## and show that this leads to a contradiction. Thus, if the particle does not make it to ##x = a## it must momentarily come to rest at some ##x = x_m## such that ##x_m < a##. Since the graph of V(x) is monatonically increasing, ##V(x_m) < V(a) = \frac{\lambda}{2a}##. Therefore, at ##x = x_m##, ##E = V(x_m) < \frac{\lambda}{2a}##. This contradicts the fact that we know the particle starts out with ##E > \frac{\lambda}{2a}##. I think this is pretty much the same as your argument.
for the last part:
You just need to make sure the particle does not make it over the hill at ##x = 3^{1/4}a##. So, argue that E must be less than ##V(3^{1/4}a)##. You know that ##E = v_0^2/2##. So, this should give you the restriction on ##v_0^2##. Note that ##v_0^2## is certainly positive, so the lower limit of ##v_0^2## will be 0.
thanks a lot for this - just one confusion - how do you know that ## E = v_0^2/2 ##?
I was thinking as ## v_0^2/2 = E - V(x) ## as ## E <V(3^{1/4}a) ## then ## E - V(X) < \dfrac{3^{3/4}\lambda}{a} ## so ## 0 < v_0^2 < \dfrac{3^{3/4}\lambda}{2a} ## is my logic here correct?
Evaluate the total energy at x = 0.
The first equation should be ##v_0^2/2 = E##. Since the graph of ##V(x)## has only one maximum (at ##x = 3^{1/4}a##), the particle will stop, turn around, and make it to ## x = -a## as long as ##E < V(3^{1/4}a)##.
thanks very much... this is my first course in physics so I'm slightly struggling, but got there in the end!
