Permanent magnet alternators on Japanese vehicles?
The discussion revolves around the feasibility of using a permanent magnet alternator (PMA) in a solar chimney system for electricity generation in a residential setting. Participants explore the technical aspects of PMAs, their application in vehicles, and the expected energy output from such a setup.
  • One participant suggests using a PMA for generating electricity from a solar chimney, emphasizing its effectiveness compared to other types of generators.
  • Another participant questions the viability of the system, arguing that the fan may stop rotating once outside air replaces the warm air being sucked out, potentially limiting the system's effectiveness.
  • Several participants note that alternators, including PMAs, typically require high speeds to generate voltage, with one suggesting the need for a gearbox to achieve these speeds.
  • Concerns are raised about the expected energy output, with one participant estimating it to be around 10 watts, while another believes a basic car alternator could generate significantly more under optimal conditions.
  • Participants discuss the characteristics of automotive alternators, noting that they usually do not use permanent magnets, which raises questions about the applicability of PMAs in this context.
  • Suggestions are made to explore alternative generator types, such as washing machine motors, which could potentially be used in the solar chimney system.
Participants express differing views on the expected energy output and the effectiveness of using a PMA in the proposed system. There is no consensus on the viability of the solar chimney concept or the suitability of automotive alternators for this application.
Participants highlight various assumptions regarding air flow dynamics, energy generation capabilities, and the design of the solar chimney, which remain unresolved and may impact the discussion.
kenward
I am incorporating a solar chimney in my house build in Thailand, this will have a venturi to create the suction for removing warm air from the building and I intend to use this high air speed area to generate electricity. As air speed will be dependent on the Sun and not the more fickle wind [here in Thailand anyway] I don't anticipate the problems associated with low air speeds and am therefore considering a vehicle alternator. I have read that a PMA [permanent magnet alternator] is the most effective type to use but are these fitted to production vehicles and does anyone know of a Japanese manufacturer who fits them so I can look in local scrap yards; which are full of Jap vehicles here.
When you suck the air out of your house, the air from outside will come into the house to replace it. When it does that surely the fan will stop rotating because the temperature difference will be lost?
In any case, this effect would only happen in for a short time in late afternoon when the house is hotter inside than the air outside.
And alternators are only good at high speeds.
I was hoping for a knowledgeable response to my question rather than an opportunity to explain how a solar chimney actually works; simpler if you go to Wikipedia and look up 'Solar Chimney'.
No idea what a PMA is then!
Actually, just about any generator is only good at higher speeds. If you don't operate at higher speeds then you don't generate any voltage. You will probably need a gearbox of some sort going from your turbine to generator/alternator.
I would imagine any of the higher end more pricey models would have PMAs in them.
Kenward, have you made any estimates of how much energy this is expected to generate?
Personally I'd be surprised if you were looking at more than about 10 watts continuous output power, but I don't know the size of the dwelling or solar chimney. I'd imagine that a 10W solar panel would be easier and cheaper if that level of power is any use to you.
Wikipedia says that :
"Automotive alternators invariably use a rotor winding, which allows control of the alternator generated voltage by varying the current in the rotor field winding."
That means no permanent magnets.
I've heard of permanent magnet washing machine motors being used as generators. The good ones are apparently the flat "pancake" type.
How tall are you thinking of making this solar chimney?
I suspect there might be a better thread like General Engineering for the solar chimney aspects of this question.
kenward,
I suggest building your own generator/alternator of the type used in DIY windmill setups. There are several free plans available on http://www.instructables.com/
Hi uart
I am looking for 50-60Watts. As a basic car alternator, not a high performance or PMA unit, can generate 60amps at 12V at optimum RPM I don't quite follow your 10 watt limit. I am no expert and understand the many areas where generated power can be lost, or not generated if you can't make the RPM, but please let me know why you believe such a low output would result.
Thanks for your follow up:
The washing machine motor is a helpful suggestion for future investigation but to 'prototype' the system I would prefer a 'plug n play' unit such as a PMA vehicle alternator, I know they do exist but just need to track one down that can be inexpensively procured as a test subject.
For commercial applications height is a big factor in generating air speed but nobody wants a 30 metre chimney sticking out of their house roof; or a 300m one as proposed in Australia. Therefore it is more a factor of efficiency in capturing the infra red waves via a collector; the resultant heat generated seeks an escape route and a carefully designed venturi will theoretically generate very high air speeds which can be harnessed to drive the alternator. I am not expecting to hit the ground running on this but know it has the potential.
  • · Replies 16 ·
15K
  • · Replies 21 ·
  • · Replies 19 ·
12K
