Perplexing integration - sqrt(1+sinx)
  • Thread starter Thread starter peripatein
    Integration
The discussion revolves around the integration of sqrt(1+sinx) dx, where the initial substitution of u=sinx leads to an incorrect result of 2sqrt(1-sinx). Participants suggest using a different substitution, specifically tan(x/2) = u, to resolve the issue. There is confusion regarding the algebraic steps and the correct handling of signs in the integration process, particularly concerning the identity cos(x) = ±sqrt(1-sin^2(x)). Additionally, a participant raises a separate question about evaluating the improper integral 1/[(x-1)^(1/3)] between 0 and 4, which is advised to be discussed in a new thread. The conversation highlights the importance of careful substitution and sign management in integration problems.
peripatein
Hello,
I am trying to integrate sqrt(1+sinx) dx but I keep getting 2sqrt(1-sinx) (having initially substituted u=sinx), which is wrong! Could anyone please tell me what I am doing wrong?
We can't really know what you did wrong unless you tell us what you did! So, can you show us your work?
As I wrote, I substituted u=sinx and got that the integral should be equal to 2sqrt(1-sinx). Which is wrong, according to Wolfram and a simple differentiation test. I am simply not sure where I faltered. May you please advise?
You're starting in the wrong place. You should be using a different substitution. Try tan x/2 = u.
I would have thought so, except that I was instructed to use that substitution. :s
It should still be correct, granted the algebra is. Yet the answer is incorrect!
peripatein, you need to show us your work. We cannot read your mind.
u=sinx, du=cosxdx
Hence, int=[sqrt(1+u)/sqrt(1-u^2)] du=[1/sqrt(1-u)] du.
Hence, int=2sqrt(1-sinx)
Try that last step again.
What do you mean? Dividing by sqrt(1+u)?
Do the integration:
\displaystyle \int \frac{1}{\sqrt{1-u}}\,du\ .
But isn't that 2sqrt(1-u)?
sign error.
Wrong link. In any case, that is NOT the answer. Question is, why?
They're the same answer *if* \cos x=\sqrt{1-\sin^2 x}. That's not always the case, but you implicitly assumed that this is an identity in your u-substitution.
What is the correct answer?
You have to be careful about sign behavior of the functions you're working with.
\displaystyle \cos(x)=\sqrt{1-\sin^2(x)}\ \ only when cos(x) ≥ 0.
Otherwise, \displaystyle \ \cos(x)=-\sqrt{1-\sin^2(x)\ .}
Okay, thanks!
I am also trying to evaluate the improper integral 1/[(x-1)^1/3] between 0 and 4. May I do so thus?:
{ lim b->1- int 1/[(x-1)^1/3] dx between 0 and b } + { lim b->1+ int 1/[(x-1)^1/3] dx between b and 4 }?
Is there a another, better way to evaluate it?
peripatein said:
Okay, thanks!
It's best to start a new thread for this.
It's a completely different problem.
11K
