Mentor
- 38,160
- 10,773
Yes, but "How are you" requests an adjective, whereas "How do you do" or "How are you doing" requests an adverb.Mark44 said:If you reply with one of these, you haven't answered the question "How are you?"
The point of @atyy's comment was the grammatical correctness or incorrectness of the response "I'm good."
It's not about adjectives or adverbs -- it's about the meaning of good vs. well.fresh_42 said:I don't get it. If the answer to "How are you?" is an adjective, then "I am good!" is a valid and correct answer, ergo nothing to object, ergo what has been the subject of @atyy's post.
I understood this. I was just saying that "How are you?" is interpreted as "How are you doing?" An answer to the former is "I am not evil." whereas an answer to the latter requires an adverb. It is the faulty question which I have objections to. It is about the question, which provokes a seemingly false answer which actually is perfectly correct, and only the lack of precision in the question makes the answer look incorrect whereas it actually is correct.Mark44 said:It's not about adjectives or adverbs -- it's about the meaning of good vs. well.
"I am good" implies that I am not evil.
"I am well" implies that I am not suffering from any disease or ailment.
Not necessarily. It can also refer to a skill that may be subtextual (although this most often is not going to be the case).Mark44 said:"I am good" implies that I am not evil.
I disagree. If the question is "How are you?" and there is no additional context about skills or abilities, then it's a leap to consider that a response of "I am good" is about skills.Orodruin said:Not necessarily. It can also refer to a skill that may be subtextual (although this most often is not going to be the case).
Right, one could interpret the question as you have done, but that's not the point. We're talking about the question as it is asked.fresh_42 said:I understood this. I was just saying that "How are you?" is interpreted as "How are you doing?" An answer to the former is "I am not evil." whereas an answer to the latter requires an adverb.
How is the question faulty?fresh_42 said:It is the faulty question which I have objections to.
You're overthinking this, I believe. Consider the question exactly as it is asked, not as some interpretation that isn't an exact parallel to the semantic meaning of "How are you?" This is similar to the difference between "What are you?" vs. "What are you doing?"fresh_42 said:It is about the question, which provokes a seemingly false answer which actually is perfectly correct, and only the lack of precision in the question makes the answer look incorrect whereas it actually is correct.
I think 'feeling' is implied and therefore missed out.Mark44 said:I disagree. If the question is "How are you?" and there is no additional context about skills or abilities, then it's a leap to consider that a response of "I am good" is about skills.
You may disagree all you want. The leap is not so large that it cannot be considered as at least a possibility, even if it most likely not to be the case in most situations - which is what I was saying. In addition, context can also be non-verbal.Mark44 said:I disagree. If the question is "How are you?" and there is no additional context about skills or abilities, then it's a leap to consider that a response of "I am good" is about skills.
Mark44 said:If the question is "How are you?" and there is no additional context about skills or abilities, then it's a leap to consider that a response of "I am good" is about skills.
I specifically said no additional context, which would preclude nonverbal cues. Again, if someone walks up to you and asks, "How are you?" I maintain that the chances of them inquiring about your abilities is vanishingly small. In that sense, it's a leap to interpret the question "How are you?" as anything other than your state at the moment.Orodruin said:The leap is not so large that it cannot be considered as at least a possibility, even if it most likely not to be the case in most situations - which is what I was saying. In addition, context can also be non-verbal.
The thread went astray with this question in post #58.symbolipoint said:Posts #69 through 71:
Is this about "pet peeves" of our native language (in this case, English), or about how logic is or is not applied to some phrases or common questions?
atyy said:You are probably one of those who would object to "How are you?" "I'm good".
I don't think it is astray. It is about an unspoken complement "doing, feeling" which in reverse affects the answer. Without it the question asks for a property, which is an adjective, with it, imagined or outspoken, the question asks for an adverb. However, the unspoken part is almost always assumed, which makes the correct answer seem wrong whereas it is not. This is about one of many imprecisions of language as a whole. And as such, subject to the thread.Mark44 said:The thread went astray with this question in post #58.
In this case, it is the fact that people far too often use the english apostrophe for genitives. We do not use it that way. In fact an apostrophe usually marks an elision, but never a genitive.symbolipoint said:Is this about "pet peeves" of our native language
And I specifically said that things may be subtextual, which would include non-verbal clues.Mark44 said:I specifically said no additional context, which would preclude nonverbal cues.
Are you thinking that "good" is an adjective and "well" is exclusively an adverb? The latter is not true.fresh_42 said:Without it the question asks for a property, which is an adjective, with it, imagined or outspoken, the question asks for an adverb. However, the unspoken part is almost always assumed, which makes the correct answer seem wrong whereas it is not. This is about one of many imprecisions of language as a whole. And as such, subject to the thread.
The scenario that I described and quoted, specifies that there are no contextual clues of any kind - overt, subtextual, ESP, whatever.Orodruin said:And I specifically said that things may be subtextual, which would include non-verbal clues.
Yes. Well, if not a noun or verb, and if not combined with another word as e.g. in well-being it is an adverb, the adverb to good.Mark44 said:Are you thinking that "good" is an adjective and "well" is exclusively an adverb?
But what @fresh_42 was talking about was not that. It was whether or not it would be grammatically correct or not, which it is. Whether or not it has a relevant meaning in the context is not relevant.Mark44 said:The scenario that I described and quoted, specifies that there are no contextual clues of any kind - overt, subtextual, ESP, whatever.
I would even say that "How are you?" - "Well." is wrong as "Quickly." would be wrong.Orodruin said:But what @fresh_42 was talking about was not that. It was whether or not it would be grammatically correct or not, which it is. Whether or not it has a relevant meaning in the context is not relevant.
No, "well" is also an adjective. See entry 5 here - https://www.merriam-webster.com/dictionary/well. Other English dictionaries would be similar.fresh_42 said:Yes. Well, if not a noun or verb, and if not combined with another word as e.g. in well-being it is an adverb, the adverb to good.
"Well" is the grammatically correct answer. This is exactly what atyy was talking about almost 30 posts back.fresh_42 said:would even say that "How are you?" - "Well." is wrong as "Quickly." would be wrong.
I am not convinced. An answer: "I am well". looks wrong. Well what? Well done?Mark44 said:"Well" is the grammatically correct answer. This is exactly what atyy was talking about almost 30 posts back.
I guess it takes a lot to convince you, but then you are not a native speaker of English.fresh_42 said:I am not convinced.
But it is correct. "Well" here is an adjective that describes the subject, "I".fresh_42 said:"I am well". looks wrong. Well what? Well done?
No, not so. From the same page: "he's not a well man" and "the wound is nearly well". In both cases the adjective "well" modifies the subject.fresh_42 said:The examples in Webster all have an elision or are directly adverbial as in "our garden looks well".
