PH and pOH and [H+] and [OH-] Problems
  • Thread starter Thread starter justinkoko
    Ph
This discussion focuses on calculating pH and pOH values for various acid-base problems involving strong and weak acids and bases. Key examples include determining the pH of mixed HCl solutions, calculating the Kb for aniline, and finding the resulting pH after mixing KOH with HCl. The solutions provided emphasize the importance of stoichiometry and equilibrium constants in these calculations, leading to definitive answers such as pH 2.26 for mixed HCl solutions and Kb of 4.0x10^-10 for aniline.
  • Understanding of pH and pOH concepts
  • Knowledge of strong and weak acids and bases
  • Familiarity with equilibrium constants (Kb and Ka)
  • Basic stoichiometry for acid-base reactions
  • Learn how to calculate pH from strong acid concentrations
  • Study the equilibrium expressions for weak bases and their Kb values
  • Explore stoichiometric calculations in acid-base neutralization reactions
  • Practice using chemical calculators for pH and concentration problems
Chemistry students, educators, and anyone preparing for chemistry exams, particularly in acid-base chemistry and equilibrium concepts.
justinkoko
1. Two HCl(aq) solutions have pH= 2.00 and pH= 3.00, respectively. If equal volumes of these two solutions are combined, the pH of the resulting solution wil be ...
Now I know the answer is 2.26 but I don't know how to actually solve it..
2.Aniline(C6H5NH2) is a weak base. At 25C, a 0.100M aqueous solution has a pH of 8.80. The Kb of aniline is..
Now I know the answer is 4.0x10^-10 but I don't know how to actually solve it..
3. 60.0ml of .100 M KOH is mixed with 40.0ml of .250M HCl at 25C. Assuming the volumes are additive, what is the pH of the resulting solution?
1.4 but I don't know how to solve it..
Please tell me how to do those..I have a chem test tomorrow :bugeye:
TIA..
Chemistry news on Phys.org
Calculate the pH of .400M Sr(OH)2
-log(.800M) = .09691
pH= 14-pOH= 13.9
Why is it .800 instead os .400M?
Is it because there are TWO OH s?
pH= 14-pOH= 13.9
Nevermind this. I figured it out.
I still need help on the problems in the first thread.
1. Assume you are mixing 1L of each solution. Calculate number of moles of HCl in each solution - if you add these numbers you will know how much acid is present. You also know final solution volume. That gives concentration, pH calculation should be easy from this moment on ;)
2. Aniline reacts with water to produce OH-. Equlibrium of this reaction is described by Kb constant. Check out how you did pH calculation for weak base (or how it is described in your textbook). You must use exactly the same equation and the same simplifying assumptions, just solve for Kb, not H+ (or OH-).
3. Simple stoichiometry and limiting reagent question - reagent that is left after the neutralization will define pH. If there are exactly the same amounts of reagents autoionization of water will define pH. So check what was left, pH calculation will be just pressing log button on your calculator...
Chemical calculators at
Borek
Genius!
Thanks for the help! :smile:
12K
