Phasor mesh current analysis not matching homework site answer
  • Thread starter teh_dude
    Mesh Phasor
6 replies · 4K views · last reply
teh_dude
Phasor Mesh Current--what am I doing wrong??
Circuit diagram:
Two-mesh AC circuit diagram with a 550∠0° V source, inductors j75 Ω and j50 Ω, j24 Ω mutual coupling, resistors 30 Ω and 80 Ω, a -j40 Ω capacitor, and a 600∠-30° V source, with mesh currents I1 and I2 marked.
Calculate the phasor mesh currents, I1 and I2.
KVL/Mesh Current analysis with phasors/complex numbers.
Mesh 1: (-550@0deg) + j75(I1) + 30(I1 - I2) - j40(I1) - j24(I2) = 0
Mesh 2: (600@-30deg) + 30(I2 - I1) + j50(I2) + 80(I2) - j24(I1) = 0
(30 + j35)I1 - (30 + j24)I2 = 550
-(30 + j24)I1 + (110 + j50)I2 = (-600@-30deg)
I got:
I1 = (9.45503221553 @ -38.8333374187 degrees) A
I2 = (2.79176352576 @ 93.1719060416 degrees) A
This problem was even demonstrated in class. Yet the homework site keeps telling me I'm wrong. I don't see where I've made a mistake...?
How did you incorporate the 600V at -30 degrees in your equations? You didn't show us that, so we can't find your mistake for you, if there is one.
Maybe check that the signs of the mutual inductance terms respect the dot notation and choice of loop current directions?
How else can I demonstrate? It's there.
If you mean how did I mix polar notation with rectangular notation, I punched it all into the TI-89, in which the modes were set to degree, polar, and approximate.
Otherwise, I don't know what you're getting at.
I don't entirely understand how to deal with the polarity marks, but I've tried switching plus and minus for the j24Ω term. It's my understanding that they should both be -j24Ω, multiplied by I1 or I2 respectively, but I've tried both minus, both plus, one minus, one plus, the other way around, and none of the answers are correct.
I've taken a closer look at your circuit and I believe that you have them correctly oriented. Sorry for the bother.
The idea is that a positively increasing current flowing into one coil at its dot produces a positive polarity of induced voltage at the dot of the second coil. So you have to be attentive as to whether a positive increase in the mesh current will create a positive increase in the current flowing into the coil dot, or whether it will in fact cause a decrease.
Circuit diagram of two magnetically coupled coils with dots at their top terminals, mutual inductance M between them, currents i1 and i2 entering at the dotted ends, and dependent voltage sources jMI2 and jMI1 with polarity marks in the equivalent phasor model.
  • Circuit schematic of two magnetically coupled inductors with dot markings, mutual inductance M shown between them, currents i1 and i2 labeled; beside it, the equivalent model with j omega M I2 and j omega M I1 controlled voltage sources added in series with each self-inductance.
That is not a viable equation. You must transform the "600V@-30deg" the same way you transform components. Example: you didn't write "wL@+90deg" for the inductive impedance, did you? You wrorte jwL. jwL is the transform of wL@+90deg. Do the same for the 600V@-30 deg. I don't know what your TI-59 is doing & I can't guess.
I checked & your mutual inductance polarities are correct and in fact your equations are correct, except the second equation is not an equation. :frown:
