Philosophy of quantum field theory
40 replies · 7K views
Insights Author
I usually don't read papers on philosophy of quantum field theory, but this one is really good: http://philsci-archive.pitt.edu/8890/
In particular, the prelude which I quote here is a true gem:
"Once upon a time there was a community of physicists. This community be-
lieved, and had good reason to believe, that quantum mechanics, not classical
mechanics, was the right framework in which to do physics. They also had
a good understanding, at the classical level, of the dynamics of solid bodies
(vibrations in crystals, for instance): they knew, for example, that some such
bodies could be analysed using Lagrangians like
L =φ^2 − (∇φ)^2 + (higher terms) (1)
where φ(x) is the displacement of the part of the crystal which is at position x
at equilibrium.
But the physicists were sad, because they knew nothing at all about the
microscopic structure of matter, and so they did not have a good quantum
theory of vibrations in crystals or of other solid-matter dynamics.
So one day, they set out to quantize their classical theories of solid mat-
ter. At first, they tried to do it naively, by putting the classical theory into
Hamiltonian form and replacing classical observables with self-adjoint opera-
tors. This worked quite well until the higher-order terms in (1) were included.
But when the physicists tried to include those higher order terms, the theory
became mathematically very badly behaved — all the calculations contained
integrals that diverged to infinity.
Soon the physicists discovered that they could extract working calculational
results if they just assumed that displacements couldn’t vary on arbitrarily
short lengthscales. This amounted to “cutting off” the range of integration in
the divergent integrals, so that they got a finite result. When they did their
calculations this way, the answers agreed very well with experiment.
But the physicists were still sad. “It’s ad hoc”, they said. “It’s inelegant”,
they lamented. “It conflicts with the Euclidean symmetries of solid matter”,
they cried.
So they went back to basics, and looked for an axiomatised, fully rigorous
quantum theory, with displacements definable on arbitrarily short lengthscales
and with exact Euclidean symmetries.
And to this day, they are still looking."
He gets points for mentioning Jon Kogut. He loses points for mixing up regularization and renormalization.
His basic point is that our working assumption about "reality" should be that there is some UV cutoff, with QFT as an effective theory per Wilson. This because the long effort to construct a mathematically sensible, UV-complete QFT (in 4D, with interactions) has failed, so perhaps such a theory cannot even exist.
Well, how is the situation with a cutoff? Do we have a mathematically rigorous account of what fields-with-cutoff are, without committing to a specific cutoff scheme such as a lattice?
It has not failed, it just remained inconclusive. Not a single argument is known that would indicate that such QFTs do not exist.
The same happens already for the ordinary quantum mechanics of a single particle in a delta function potential, which is perfectly well-defined if one takes the right limit. No cutoff is needed.
Thus the bad behavior just means that the naive approach was wrong, not that cutoff is the natural remedy.
I disagree. Even if there is a way to treat the delta function rigorously, from a physical point of view a cutoff is a natural remedy. In nature we don't have potentials that look exactly like a delta function, but we do have potentials that look like very narrow Gaussians.
This is not a good argument. In nature we also don't have real or complex numbers, but without them physics - including your favorite, Bohmian mechanics! - would be impossible.
Bohmian mechanics (and quantum mechanics) can be written down in terms of real numbers only, without using complex numbers. And more to the point, it's possible to approximate (arbitrarily well) quantum/Bohmian mechanics by using a (sufficiently large) discrete set of numbers instead of reals.
martinbn said:
What exatcly is the point of this paper?
It is explicitly a philosophy paper. The point is about which concept of QFT should be thought of as "true".
The paper is about how to think philosophically about UV divergences in QFT. In my own words, I would say that it argues that a "naive" cutoff way of thinking is in fact better than attempts to retain continuum with a fancy-schmancy functional analysis way of thinking.
How long must a research program run without results, before we are allowed to say it has "failed"?
The basic problem is by now well-known: if the fields are operator-valued distributions, then defining interactions as products of fields at a point doesn't make sense, because distributions cannot generally be multiplied. Some distributions can be multiplied using Hormander's method, but the time-ordered product fails Hormander's criterion.
Is there any good reason to believe this issue can be overcome?
Is there a necessity for this? If the cutoff is something physical, that means, there is some more fundamental theory and this theory has an effective cutoff. So the real world is, metaphorically, committed to a particular cutoff. We have to guess the correct theory, and that means, we also have to commit to the particular cutoff scheme which is equivalent to the true fundamental theory.
Epstein-Glaser?
In mathematics and mathematical physics, something has failed only when its goals are proved to be unattainable. Examples are the quadrature of the circle or the trisection of angles with rule and compass.
Kepler's conjecture (that the face centered cubic lattice gives the densest lattice packing in 3 dimensions) was positively settled after having been open for more than 300 years. The Riemann hypothesis is over 170 years old and still considered to be one of the most important open problems in mathematics. Quantum field theory is much younger.
Note that good problems yield many interesting results even when the main problem remains unsolved for a long time. This was not only the case for Kepler's conjecture and the Riemann hypothesis but also for algebraic quantum field theory. In 2 and 3 dimensions the existence of interacting Wightman fields has been constructively proved. The 4-dimensional case is simply significantly harder.
Yes. Causal perturbation theory addresses precisely this point. See my insight article on [URL='https://www.physicsforums.com/insights/causal-perturbation-theory/']causal perturbation theory[/URL].
But the approximate theory loses all properties that make the theory physically interesting. For example, the continuity equation goes down the drain.
Demystifier said:
What do you mean by that?
Discrete approximations do not satisfy a continuity equation. hence the basic mechanism of Bohmian mechanics is no longer justified.
This flashed a light bulb in my head. We learn to be accustomed from very early on with real numbers and limits and I guess we don't really think about how weird all these things are. The delta function is a good example of this. I guess it is easy to forget your approximation is not more fundamental than nature.
Though I also understand what Neumaier is saying. One has to be careful not to throw the baby out with the bath water.
A. Neumaier said:
Causal perturbation theory does not work with Lagrangians!
In your insights article you write: "
To define particular interacting local quantum field theories such as QED, one just has to require a particular form for the first order approximation of S(g). In cases where no bound states exist, which includes QED, this form is that of the traditional nonquadratic term in the action, but it has a different meaning."
Exactly in what way is the meaning different from the one in the traditional action? Does the approximation follow an local action principle or not?
It looks to me like it just uses a renormalized Lagrangian instead of the usual bare one since it changes the moment when the renormalizations is performed to a previous step instead of the usual latter one. But the local action is still there in the background, just more rigurously renormalized from the start.
Discrete entities, like atoms, which are conserved and can be counted, with either continuous trajectories or, if even space is discrete, switch only to neighbor cells in each time step, are the straightforward microscopic models for things described by a continuity equation. To justify the continuity equation in the large distance limit is, in this case, quite trivial. Thus, no basis is lost.
What I would like from a theory of QFT-with-cutoff is a rigorous formulation and proof of the idea that the details of the cutoff do not matter. For that, I think we need a cutoff-independent formulation of the concept of a cutoff itself, and of the fields subject to it.
Remember the context of my statement! Continuous trajectories are impossible without using real numbers.
Discrete trajectories may conserve the particle number but not via a continuity equation. Moreover, the conservation of particles is known to be violated in physics, while the conservation of various currents follows from symmetry considerations. All this is lost when avoiding real numbers.
As if this is what anyone actually does in practice. More like the merry band of physicists made it all work by working in 4 + *whatever* dimensions and arbitrarily tuned some constants so the Green's functions would fit certain conditions while leaving the rest of the theory in a complete divergent mess.
In other words no value at all.
This would require first a proof of the unfeasibility of the standard mathematical continuum way as commented by Neumaier, and if that happened it is not clear what kind of theory that situation could allow to construct, at least with the current concept of the mathematical continuum of the reals.
Unless you don't mind the same judgement for your post could you elaborate a bit on why no value at all?
Again, this is explicitly a philosophy paper. If you do not appreciate philosophy, then you are not meant to find value in it.
Because some comments have been moved, I will reproduce the reevant part of the conversation before responding:
Demystifier said:
Epstein-Glaser?
maline said:
I don't know very much on these topics, so please enlighten me if I'm wrong. But if I understand correctly, Epstein-Glaser and the like merely describe in precise terms how renormalization is to be done, without making any attempt to justify the procedure "from first principles". They don't describe what it is that we are trying to calculate using these prescriptions. They provide an answer, but not the question!
Indeed, this will be true of any formalism that begins with a Lagrangian. Renormalization does not allow us to calculate the observable values of masses and coupling constants from the Lagrangian, meaning that predicting physical values requires some additional input. A properly specified theory would include "fundamental" parameters that eventually fix the measured values. If all we have is a Lagrangian, we simply do not know what we are calculating.
Another aspect of the same thing (I believe) is that Epstein-Glaser is fundamentally perturbative - that is, the power series is the only output; there is no function that the series is intended to approximate!
So I'm not sure these methods bring us any closer to explaining what we actually mean by QFT interaction terms...
In the causal approach, the meaning is precisely given by the axioms for the parameterized S-matrix. The construction is at present perturbative only. Missing are only suitable summation schemes for which one can prove that their result satisfies the axioms nonperturbatively. This is a nontrivial and unsolved step but not something that looks completely hopeless.
Okay, I admit that this axiom-based approach is more successful than I gave it credit for. It's not just "here is a well-defined algorithm that that reproduces what physicists do", but rather "if a full theory exists at all, with the desired first-order term, then we can prove that this algorithm gives the correct power series expansion for the full theory".
The Hilbert space is the asymptotic Fock space with the empirically measured masses, and the measurable coupling constants are fixed by the finite coefficients given in the first-order term (is this correct, or is there still an arbitrary choice of renormalization scheme that changes the predicted values?)
Nevertheless, this approach provides no evidence at all that the full theory does in fact exist. Nor do we have any other reason to think it does! We know that the standard formulation, in terms of integrating a Hamiltonian, is meaningless because of the improperly multiplied distributions. Having a procedure to deal with them does not change that fact.
The experimental success of QFT cannot provide evidence that it exists mathematically, because they occur in a universe that, at high energy, is dominated by quantum gravity. Whatever the true quantum gravity looks like, we have little reason to think it is a QFT on a background manifold. So our experiments are very unlikely to be the outcome of any UV-complete QFT!
Thus we have little or no reason to think any (interacting, non-super-renormalizable) QFT exists, and the ongoing lack of success in finding one provides at least some evidence that it does not.
