Photoelectric current: why does it decrease?
3 replies · 2K views
BasilBassam
In my book it is stated.When you keep the intensity constant and decrease the wavelength the photoelectric current decreases but I can't understand why?
I thought it would stay the same since photoelectric current depends on the intensity of photons as more number oh photons means more e- released
Are you talking about stopping potentials experiments? As in when EM radiation falls on a plate A and a potential difference is applied across plates A and B such that B is more negative?
Should that not be the other way around?
The electrons are not just being released from the surface. The ones further inside need to have more energy to escape the surface. If the wavelength of light is shorter electrons from further inside will make it out.
The experiment is you supply light (photons) on a metal surface to release e-
then they said 240 nm wavelength of radiation gives Max Photoelectric current.After that they said Intensity is constant and wavelength is reduced causing the current to decrease but I simply can't understand why
