Photometry / radiation question
To find luminous intensity from given radiant power and luminous flux, use the formula for luminous intensity, which is luminous flux divided by the solid angle in steradians. In this case, with a luminous flux of 22 lumens spread over a hemisphere (2π steradians), the luminous intensity is calculated as 11π lumens per steradian. For illuminance at specific distances, further calculations using the luminous intensity will be necessary. The radiant power provided is not needed for calculating luminous intensity. Understanding the relationship between photometric and radiometric units is essential for these calculations.
ginnerpip
Hey guys (and girls)
I've got a rather annoying question.
If you were given the radiant power (45 mW) and luminous flux (22 l), and then was told it was spread uniformly spread over a hemisphere. (a) how do find the luminous intensity??, (b) the illuminance 1.8m away, and (c) illumance 5.0 cm straing out, and 3.0cm to the side.
The first questioj is really annoying me, any help??
Thanks
Science news on Phys.org
What about the rest of us?
Phew, all those funky optical jargon units are pretty annoying sometimes.
Let's see:
Radiant energy is Q_e, so radiant power is probably \frac{dQ_e}{dt}, measured in Joules and J/s (Watts).
While luminous energy is measured in lm-s (talbot)
and the luminous flux is \frac{dQ_v}{dt} where Q_v is the luminous energy. The unit of flux is lm (lumen).
the Luminous Intensity (candlepower) I_v is lm/sr (lumen per steradian) or cd (candela).
You have to have some formula for switching from photometric units to radiometric units. According to my opicts book it's:
photometric unit = K(\lambda)\times radiometric unit
where K(\lambda) is the luminous efficacy.
The first question is not so tough. Since the luminous flux is 22 lm and the luminous intensity is lm/sr and a hemisphere has 2\pi steradian, the luminous intensity is 11\pi lm/sr.
You really don't need the radiant power after all.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
